GB For Salas I-Select Mesmerize Type input selector and volume control
Joined 2006
The I-Select board takes the selector functionality and volume control from the old mesmerize boards and implements in a standalone fashion.
This gives one a relay based selector control, relays perform reliably with great longevity and have superior electrical isolation characteristics.
This can also act as a standalone passive preamplifier, or be tied to the input of the DCB1, DCG3 or any other type of input for that matter.
The boards are $16.00
I am making a minikit available for this. It will come with no volume control, 4 inputs and a selector switch. However, read the guide, there are other ways to set this up to gather off a previous DC output voltage, and to power another unit if need be. So this is just a 'basic' type kit. More relays available on request.
4-EA2-12NJ-12V relays
8-1N4003G
1-EEU-FC1V222-Panasonic FC 35v 2200uf
1-Molex 2P Terminal Block Black
1-Headers & Wire Housings HSG 7P SINGLE ROW
1-Headers & Wire Housings 7P STRT 1 ROW GOLD 5.5MM MATING PIN
4-Headers & Wire Housings 3P STRT 1 ROW GOLD 6.8MM MATING PIN
4-Headers & Wire Housings HSG 3P SINGLE ROW NON-POLARIZED
25-Headers & Wire Housings 22-24 TERMINAL BULK
1-Wakefield 637-10ABPE heatsink
1-7812 voltage regulator
1-Rotary Switches ROTARY 2POL 6POS NS Alpha
1-Vishay MBB Through Hole .6w 10k 1% 50ppm
1-Kemet Film Capacitors .1uF 100volts 5%
1-20ma LED
$36.00
  • I_Select (2).pdf
Joined 2006
The GB for the Salas boards is open for payment up until 11:59PM EST 06/26/2016.
Payment is via PayPal invoice only in US dollars. You will need to send me your paypal email via private message for me to start this process. Then I will invoice the parts you requested from the spreadsheet. If you reply to this email - cut out some of the existing text, otherwise the message is too big.;)
Customs forms
DO NOT ask for me to fudge up a customs form with really low amount. These are based on a reasonable wholesale price.
Shipping
In general boards are a set costs, and mini kits are built into the shipping costs and larger full kits are 10.00-12 to ship. Starting price for shipping is 8.00 for just a small board and can rise from there.
The boards will ship around 2-3 weeks after the GB closes typically. The boards need to be ordered, I don't have them on hand.
In-Select
Relay based selector board with volume pot input for preamplifier 16.00
GB Thread below
http://www.diyaudio.com/forums/grou...nput-selector-volume-control.html#post4716031
MiniKit BOM section. This links goes to full details of all the parts included in the kits and there respective positions on the board.
http://www.diyaudio.com/forums/blogs/tea-bag/741-salas-board-minikits-full-kits.html
