Maybe I should go for chip amp!
hello
is there a difference between them
besides 2 x and 4 x tda7294 tda
yes, they are very different.
The red PCB is a pair of bridged channels and can only be used with 8ohm speakers.
The blue PCB is a pair of channels and can be used with 4ohm, or 6ohm, or 8ohm, or 4 to 8ohm speakers.
The Blue has UPC protection chip.
The blue has opamp input !
I was ironic BTW
If you put something more in a kit ,I'm sure the goal is to 'catch pigeons' .
That buffer could be anything ...who knows...a DSP correction :)
and someone may think that a 'buffer' may be a plus . But it only guarantees a high impedance load to the device attached .
Reading the 3886 DS it is clear that it was projected to have an 'high acceptance' input ,thus not needing any buffer . Some people have reported that using vacuum tube for that duty is much better .
