New RCF Bass drivers LN16S400/LN19S400
I would go with some type of BP enclosure with these drivers if you are concerned about voicecoils.
Or, feed the BR enclosures more than the rated power.
Here is 2 x 16" BR enclosure.
1710174845694-png.1284786
The electrical impedance and maybe some other stuff looks wrong.not possible. BP also does not work that way.
And as with any conventional bassreflex box, it only takes for the DJ to pick the note to push into visitors intestines and ears to be the same as the port tuning frequency, and you are done. Either heavily compressed or limited or burnt. My approach with zero impedance minimum (yours is not valid interpretation of the box) cannot be put in such situation.
It's not a BP enclosure. Your original request was small BR enclosure.
It might be the HR version. I only have 50.70. I cannot update to the current version due to IT security on my work laptop. However, David MacBean said that's the best way to model a BR enclosure on his program. I usually just use the Vrc, Lrc, Ap, and Lpt fields to model a BR enclosure.
Reactions: 1 user
