Did the old software do that? I can't remember. Having it appear in whatever format your computer uses would be nice.
Nothing crazy about the US format, it based on the way we say the date. 12/24/1946 is December 24th, 1946. In French it is le Vingt-Quatre-Décembre, 1946 or 24/12/1946. Similar to "the twenty-fourth of December, 1946" or 24/12/1946..
But whatever you use, the forum should be able to display your preference.
EDIT: I don't see anything in the profile settings. Maybe its a global setting
If this forum software ever gets that feature, every user could just use the format they want.
But that takes a lot of space. ISO 8601 FTW.$ LC_TIME=ja_JP.utf8 date +%c
2021年12月23日 10時00分58秒
$ LC_TIME=de_DE.utf8 date +%c
Do 23 Dez 2021 10:01:34 EET
Please send a screenshot of where the date you're referring to is, as there are lots of dates and formats all over the place, which should all be appropriate for the use case.
In general, the plan is to use the international format YYYY-MM-DD where a local styled date isn't appropriate.
I was referring to ferret's comment about user's locale-specific date/time display, or as he said, "format used in the PC settings".Please send a screenshot of where the date you're referring to is, as there are lots of dates and formats all over the place, which should all be appropriate for the use case.
As an Australian stuck in between AU/GB/US/SAE/Metric worlds, the YYYY-MM-DD is the only format I've found to be immediately obvious as there is no possibility to confuse it with another format.
I did some digging and in XF the date format is defined by the language. It's possible we could have this selectable in the future. I'm going to flag this as a lower priority but put it on the roadmap. For now we'll stick with international, but adding MM-DD-YYYY and DD-MM-YYYY might not be that hard to arrange as a selectable option in your control panel.
If you go to https://www.diyaudio.com/community/account/preferences you will now see 3 options for language, offering international, US and British (is there a better name for this?) date formats.
- Site
- Forum Problems & Feedback
- Resolved - Implemented Option to change date format
