Post your Analogue Source pics here
Nice TT!!
Can you please tell me where you got the mag lev platter bearing. Also if possible the platter weight and magnets dimension.
Many tsk
Adelmo
Hi.....sorry I missed your question...I don't seem to get notifications from this thread any more.
Essentially I made the bearing myself.
I think that I bought the magnets from an eBay seller.
It is just two N52 neodymium ring magnets in opposition to each other. Their dimensions are roughly 100x60x5 .They produce a "lifting force" of 15kg with a 5mm air gap..... so I machined my platter to that weight.
To work with these motors, I use this circuit
Fully balanced phono preamp
Here is my fully balanced phono preamp for MC cartridges, using LL1941 step up transformers and 4 X Tesla PCC88 tubes. Adjustable Gain: 62,66,72dB and Loading adjustment on secondary of LL1941 to match the cartridge. I used two case design for low vibration and to keep away the transformer from tubes. It has a mute circuit with delay. Maida style regulator on phono PCB, heaters are regulated.
image003.jpg image002.jpg image001.jpg image005.jpg image004.jpg image010.jpg image009.jpg image007.jpg image008.jpg
Reactions: 1 user
Here are some before and after shots of a recent restoration I did on a Technics SL-150.
Reactions: 1 user
Phonoclone with Salas shunt regulator
[/URL]
[/URL]
[/URL]
Thorens TD850 with SME309 tonearm
plus DIY motor power supply and motor base
[/URL]
