Hi Vunce,
I am going to have to lower the voltage from the Yarra psu to 24v for the Hakuin. You had posted the following for member meanie"
If using Ohm's Law V=IxR, solving for R saying I need a 4 volt drop would be R=4V / I . What is a good value for I ?
Thanks for the help,
Hi Meanie,
I also run 22v trafos in the Yarra capMx psu. The way I reduced the voltage is increase the CRCRC resistors on the daughter board itself to lower the voltage.
My PCA’s use 47R and 33R in those locations for approximately a 7-8v drop. I don’t remember what my Hakuin values are. Use Ohms Law to calculate what the resistor values need to be for your voltage drop.
