TDA1387 octal DAC looks like a good modding base
Posted 16th January 2015 at 12:55 AM by abraxalito
Updated 28th August 2015 at 01:16 AM by abraxalito
Thanks to Matthieu (Malefoda) for the heads up on this. It looks distinctly like a DAC inspired by the DAC-AH - note not only the 8 DAC chips but also the PCB layout closely follows that design's. The price on Taobao is about half the AH (368rmb) so I shall be ordering up one or more to have a play. Matthieu found it on another website with prices in USD, here - https://www.cart100.com/Product/42124644877/.
Note there are two options here (blue, black) - the cheaper one is a kit of parts I believe, the more expensive ($84) the finished unit. Going on the translation of the Taobao page, the kit does not include the transformers, mains switch or the case.
Update : here's the summary of the mods so far, for details go to Malefoda's thread linked in the comments.
1) Re-route the output ground so the opamp filtering caps aren't subject to injected CM noise from the destination component (amp or pre).
2) Reduce the supply voltage to the output opamps so X7R caps can be used between the rails to good effect. Lower voltage on X7Rs means higher capacitance so really there should only be enough supply rail volts to achieve the desired output level (2VRMS). Increase the resistors feeding the shunts (add 100R in series with existing 150R).
3) Fit 10uF/25V 1206 X7Rs across both opamp supply pins (4 per chip). Remove the 4 film caps doing decoupling. Change 10k output grounding resistors to 1M.
4) Swap out the NE5534s (if yours has these) for something a bit more RF-resistant and unity gain stable. So far AD845s sound excellent but I'm going to try others.
5) Remove 8 ceramics on TDA1387 pin7s and replace with 8 * 1000uF/6.3V lytics.
6) Remove 2.2nF caps in feedback network of opamps.
7) Include a 2 pole LC output filter with series L and shunt RC arms to attenuate the OOB image freqs and boost the HF, overcoming 'NOS droop'.
8) Experiment with classA loading the opamp output stages with resistors (or current sources) to the -ve rail.
9) Add more capacitance to the DAC chips' supply, depending on how much bass clarity you're after.
Update - here's a pic of how the modded one is looking Eagle-eyed viewers might notice a mod or two which I've forgotten to mention above.....
Update2 - matt has a Wiki about this DAC now which references this blog, so there's going to be some duplication between here, the thread and the Wiki. No bad thing. Here are the more recent mods I've been doing, many of which are mentioned in more detail (with supporting schematics) on the thread:
10) Remove the two opamps entirely and go over to single transistor I/V in differential mode. This entails splitting the 8 DACs into two camps, + and -, 4 in each and this means 4 I/V transistors. A digital inverter feeds the negative polarity DACs. Then fit LC filters (I'm currently using 5th order quasi-elliptic) between the outputs of the I/V stage and some classA discrete buffers. Finally feed the balanced outputs to a trafo to convert back to SE. The discrete buffers I've powered with +/- 7.75V supplies by reducing the voltage on the shunts that used to feed the opamps. This choice of rails allows me to use some low ESR 16V rated caps.
Subjectively the result is purer HF - noticeable on violin especially. I take it the improved treble sweetness stems from the fact that there are now no classAB stages to generate rail noise - all the active circuits are pure classA once this is implemented. The active I/V stage makes the DAC sound like it has far more capacitance on the supply rails. This I surmise is because the DAC's performance in passive I/V is limited by the biassing (pull-up) internal CCS. Presenting a much lower impedance to the DAC output means the CCS's PSRR has less of an effect.
11) Improve the PSRR of the shunts by replacing the feed resistors with LM317Ts configured as CCSs. Include ballast resistors in series with the LM317s as they have a nasty tendency to go unstable when they drop too many volts (say more than 5V). Bass performance seems to improve (fairly subtly) from this mod.
Update3 - pic of the underside posted showing the pin7 caps added (two per DAC chip). Also visible is the 74HC04 used to create the inverted phase data - 5 out of 6 inverters not used so their inputs are tied to the power rail. The PCB bottom right is a passive LC filter on the DAC's power rail.
Total Comments 10
Comments
Posted 21st January 2015 at 01:48 PM by Malefoda -
Excellent, looking forward to contributing to your mod thread I have some new Sumida 2.2mH inductors coming any day now so they could be just the ticket for an output filter for this puppy....
Got the Sumidas - minor disappointment as they turn out to be rather lossy going much above 1kHz. Their Q is poorer than the TDKs at 20kHz (around 25-30). But for lower freqs they may turn out to be useful, for example creating a PLLXO at 3kHz or so, they're higher Q than TDKs.Posted 22nd January 2015 at 01:08 AM by abraxalito
Updated 22nd January 2015 at 01:53 PM by abraxalito -
Any idea what the usb receiver is in the unit? I can't translate the description!
Posted 24th January 2015 at 12:42 PM by lordearl -
I'll confirm when I get one, but on all the Chinese DACs I've ever seen close-up with USB they've used CM106 or something similar and then route its S/PDIF output into the S/PDIF receiver.
Now Matthieu has posted up pics we have an answer to this question - there isn't one. It needs a plug-in module to handle USB which appears not to have been plugged in.
The unit's been ordered now, expecting delivery Wednesday 4th....Posted 25th January 2015 at 12:13 AM by abraxalito
Updated 5th February 2015 at 12:20 AM by abraxalito -
Posted 3rd February 2015 at 07:39 PM by Malefoda -
Posted 4th February 2015 at 12:34 AM by abraxalito -
You can warm up
https://www.diyaudio.com/forums/digit...music-not.htmlPosted 4th February 2015 at 09:39 PM by Malefoda -
Posted 5th February 2015 at 12:10 AM by abraxalito -
Just got mine, opening the box I notice its very cold ( overnight was just below freezing) and Beethoven's Pastoral Symphony was playing from my QA550. Its rough at the top definitely - the piccolo in the storm scene sounded more like a very piercing penny whistle with no depth localisation, the violins are ragged. But I'll give it some time. Dynamics aren't too bad at all, depth cues are all muddled up, sometimes depth is there, sometimes not.
Posted 5th February 2015 at 05:52 AM by abraxalito -
For the minimal modding effort (less than an hour overall so far) this is a substantial bargain of a DAC - having just installed 8 * Rubycon 1000uF/6.3V caps on the pin7s, the 'weight' has improved a lot, much more tonal balance now across the spectrum. Very pleasing to listen to, I'll let it burn in for a few hours....
Posted 5th February 2015 at 08:38 AM by abraxalito
