Digital that sounds like analog
Posted 10th December 2012 at 04:18 AM by abraxalito
Updated 15th February 2013 at 06:11 AM by abraxalito
For those who missed Frank (fas42)'s link on a thread I started then here's where I'm continuing my minimal oversampling DAC developments for the time being : Digital that sounds like analog
Total Comments 108
Comments
I'm curious whether you've noticed this effect at any time, in your experimenting - and, where you able to listen to that clip at a decent enough quality to pick the transition taking place?
I've personally found the timescale can be anything from several minutes, to the length of a CD or longer. I've never had the instrumentation to really ascertain what's happening, but in essence it appears, sounds as if the DAC mechanism is gradually tipped, or edged into a state of electrical imbalance where it develops that classic, undesirable, "digital" sound.
Playing at louder levels can make it happen faster, but I believe this is purely because the amplifiers working harder spawns more interference from stressed power supplies.
I've long had a simple method of "measuring", and resetting, the effect. Run the system until the sound is well and truly "off", and then listen to a particular track that you use as a test piece. Immediately switch off all the gear; DACs, amps, etc, but leave only switched off long enough until all the smoothing caps have fully discharged. Power up everything again, and immediately listen to that test track again. If the problem exists then this track should sound definitely, or even dramatically, better than on the first listen.
FrankPosted 8th January 2013 at 10:35 AM by fas42
Updated 8th January 2013 at 10:37 AM by fas42 -
I haven't noticed it happening over time with my system no. I was able to listen to the clip just too bored to. Listening to other people's systems via Youtube just doesn't teach me anything, I prefer to be working on my own system.
My suspicion is that the system must have a CM noise problem - perhaps the transformers are the things changing over time. Certainly iron cores have properties which change over those timescales. Ferrite does too.
One thing I noticed early on in my travels - I was using small ferrite cored inductors to protect opamp inputs from RF. On first fitting them the sound was fine. But then after a day, it went back to how it had been before - harsh, sibilant. This lasted about another day and we then returned to the clean sound which didn't change subsequently. This effect was quite repeatable on first modding a pair of active speakers with said inductors. Charles Hansen I believe has had uneven experiences from using ferrites.Posted 9th January 2013 at 02:42 AM by abraxalito -
Very interesting to hear you say firstly that you didn't have such an experience; followed by a story which in fact details you having the very thing!
My experience has been that the more recent gear is less prone to these problems than older stuff, whether by design or happenstance. It is extremely difficult to pin down precisely the origin of these sorts of issues a lot of the time, trial and error comes into it; if you don't have the artifacts up front it's a good, and a bad thing. Good for obvious reasons, bad because the gremlin can come and strike you at the worst possible moment, such as when you're demonstrating to a 3rd party -- Murphy always wins!! :D
My suspicion with the ferrites is that the stability of the winding is the culprit: while installing, soldering in place the wire is disturbed with the handling. Now somewhat physically "disturbed" out of its normal "resting" state it manifests the very symptoms I'm speaking of, but with time the wire "settles" down into a "relaxed" orientation again.
I would suggest as an experiment to deliberately manhandle the ferrite winding in situ, just a bit roughly, to mimic the installation handling, and see whether the rough sound comes back again. And then goes away also ...
FrankPosted 9th January 2013 at 04:04 AM by fas42
Updated 9th January 2013 at 04:06 AM by fas42 -
Posted 10th January 2013 at 12:37 PM by abraxalito -
Nearly all the distortion phenomena I worry about have varying timescales, from minutes to many hours. The type which most people are concerned with, which are easily measured, have timescales of the order of seconds. For example, the RF related interference artifacts that I have noted are almost instantaneous: switch on a problem device, sound immediately degrades; switch it off, sound immediately regains quality.
What is clear is that everything matters, and really the biggest hurdle is determining where and why the next most "problematic" behaviour is ocurring.
The extremely heartening overall result I've achieved is understanding that all audible bad behaviour [I]can[/I] be eliminated, meaning reduced to a point where it is subjectively irrelevant. Hence my motto, "there is no such thing as bad recording" -- if the playback of a track is subjectively not "right" then it always, always tells me that there exists a fixable issue ...
Current, highly compressed, pop recordings are excellent candidates: do yourself a favour, as a local music "guru" is famous for saying, and try a recent Foo Fighters album at high volume. If your system can unravel this cleanly then you're travelling well ... ;)
FrankPosted 10th January 2013 at 11:13 PM by fas42 -
BTW, you're doing a nice job, working the crowd in the "other place" -- I'm impressed! :cool: ...
FrankPosted 13th January 2013 at 11:05 PM by fas42 -
Posted 14th January 2013 at 02:28 AM by abraxalito -
Still workin' over there ... :)
I will take issue with this:
[QUOTE]When I listen to DSD-mastered CDs I notice that the noise seems to be added at HF - bass dynamics remains fairly decent, but the top end gets congested, fuzzy[/QUOTE]
If you're hearing this then you've got a system problem: congestion in the top end is the giveaway that there is a solvable issue in the playback side of things; dumping the blame on the recording is an easy way out ...
Why do I say this? Because this is exactly what I've been dealing with for years: fuzzy, congested treble in "poor" recordings. Like most, decades ago I just passed the blame back to the record companies, etc, but I don't use that excuse any more. I [I]know[/I], because I've done it over and over again, that such recordings can be revealed to be pristine clear, but [I]only[/I] if I eliminate every last ounce of added distortion, contributed by my system weaknesses ...
FrankPosted 2nd February 2013 at 01:37 AM by fas42 -
So why do only some recordings show the HF congestion and not others? And also why does the presence of HF congestion correlate with S-D (DSD) recordings almost perfectly? Its not that the recordings are 'poor' ones, rather its that they've used particular ADCs.
If you have answers for these questions then (and only then, no interest at all if you have no suggestions on them) what would be your suggestion for what my system is doing wrong? Incidentally did you see the THD measurement of my chipamp? Any criticism to raise there?Posted 2nd February 2013 at 10:29 AM by abraxalito -
When my own, I repeat, my own system is not in "good tune" certain recordings, styles of recordings, will show up as being worse off. Typically these will be more modern recordings, that done using more recent studio techniques, which for want of a better term, use more "digital" approaches. Historically, this will probably show to correlate almost perfectly with the wholesale use of S-D converters, and hence the linkage.
My thinking is still evolving on what underlies all this, but perhaps bizarrely to you and others, it's because these recordings have a greater effective dynamic range that they sound "worse". Older style recordings have an inherent noise floor in the recording which is higher, which is a highly effective masking agent for sounds which can unpleasantly intrusive. It can be likened to the distant water fountain in the city effect, the soothing, random hissing and gurgling of the water distracts the mind from the grinding sounds of the street traffic.
The street traffic noise correlates with HF congestion obviously, and the latter is a mixture of wanted, recorded, low level sound, and distortion. Which the ear can't separate, hence it becomes a "bad" recording. I have a nice collection of such albums, which are good "stress tests" ...
Answers? You are very familiar with many of the techniques I use, so your thinking is certainly in the right space. Power supplies, grounding are the obvious ones you've done plenty about already.
HF congestion is also the giveaway marker of interference effects. How I would address the situation there would be to temporarily shut down every, I repeat, every source of possible interference to as far away as physically possible. Every outlet switched off, power cord in the house, flat, pulled out, all lights off, all wireless devices switched off, mobile, cordless phones, even the circuit breakers in the power box pulled. You want the environment of your system to an electrical desert, apart from obviously the circuit supplying the system. Having thoroughly warmed up, conditioned the system beforehand, put on a particularly "nasty" test track, how does it sound? Give it time to settle in, put it on repeat perhaps. If there is a difference, start putting electrical devices back on line, one by one - you get the idea.
This is a technique I've used over and over again to isolate where my problems may be coming from. How you "fix" it then obviously depends on everything ....
FrankPosted 3rd February 2013 at 01:12 AM by fas42 -
I'm appreciating what a character Lynn Olson is, from his comments "over there", he's been in an excellent position to monitor the amount of crud that actually ripples through real circuits, from his own and acquaintances' monitoring. I have not been fortunate enough so far to have access to the right gear that picks up this sort of goings on everytime, so I stayed with good ol' reliables, the ear/brain. This has always told me that normal audio sound is full of muck, and whether I'm going in the right direction or not ...
His approach is obviously very different from mine, but it appears he has the same goals. The fact that a totally alternative philosophy can achieve satisfying sound merely emphasises that the end point is very real, and is essentially the same for everyone. The language used is the giveaway, he noted his surprise that "bad" recordings could sound, well, not bad!
Audio [I]will [/I]get there in the end, there are enough people out there with enough passion, and part-knowledge to make it happen. The fumbling in the dark, pawing the poor elephant in the room, trying to understand the bigger picture, will finally combine to give everyone the "good stuff" ...
FrankPosted 24th February 2013 at 11:08 PM by fas42 -
Yep, Lynn's writings have been a major encouragement to me over the past couple of years in terms of maintaining the passion for 'audio nirvana'. Where he differs from me is mainly in the realm of cost - his Karna amp is pretty expensive, even to build for yourself. I'm motivated much more by bringing digital to the mass market - which ultimately means portable. This rules out valves
Posted 26th February 2013 at 04:14 AM by abraxalito -
I'm watching the tussle with xiphmont with great interest ... the man's got a bit more ammo than I did ... ;), :)
FrankPosted 1st March 2013 at 12:08 PM by fas42
Updated 1st March 2013 at 12:19 PM by fas42 -
Posted 2nd March 2013 at 03:24 AM by abraxalito
Updated 2nd March 2013 at 06:37 AM by abraxalito -
Taking turns ... I like it! Good viewing from the dress circle ... :D
FrankPosted 2nd March 2013 at 10:01 AM by fas42 -
Posted 2nd March 2013 at 10:49 AM by abraxalito -
Okaaay ... I was wondering why the conversation turned tetchy in that way at the end there ...
And, of course, you now have Monty back to keep the party lively ... :)
FrankPosted 2nd March 2013 at 11:05 AM by fas42 -
Posted 2nd March 2013 at 12:01 PM by abraxalito -
Monty [I]is [/I]having a hard time getting through, the latest round demonstrates that the frustration felt by even the most reasonable person can be overwhelming, trying to deal with the twisted thinking of so many, especially those who should know a lot better
So much of this game is tied up with confusing faults of implementation, "bad" engineering, with supposed inadequacies of the fundamentals. And while this tangled nest of worms continues to writhe, everybody stumbles around in the dark trying to make sense of the elephant -- how that's for a brilliant mixed metaphor ...!!
FrankPosted 4th March 2013 at 10:42 PM by fas42 -
Posted 5th March 2013 at 01:41 AM by abraxalito
