Some more parts arrived for the BH
Posted 26th November 2009 at 10:10 PM by Bas Horneman
Updated 27th November 2009 at 09:40 AM by Bas Horneman
specifically I wanted to show the deflex washers that I'm planning on using.
![Click the image to open in full size.](https://www.diyaudio.com/forums/blogs/bas-horneman/attachments/66d1259273439-some-more-parts-arrived-bh-deflex.jpg)
The deflex washers will probably look ugly. But I'm planning on putting them on top of the aluminium top plate. And having a bolt with separate brass washer "hang" on them. This bolt will then pass through a larger hole in the alu chassis plate to the wooden sub chassis that houses the tubes.
Also got the 470uF/100V caps for the bias blocks.
Total Comments 0
