If I put my notes here, I might be able to find them again later!
The (Shunt-Source) S-Reg Voltage Regulator
S-reg voltage shunt-source regulator for line-level audio circuits.
This is designed to accept rectified 12x2 VAC input, producing +/-12 V output split rails.
Features soft-start and over-current protection, standard configurations for load currents up to 50 mA. High performance: 80 dB ripple rejection up to 100 kHz.
update: BOM uploaded
update: web page (stub)
Total Comments 2
Comments
Posted 19th December 2016 at 03:09 PM by dimkasta -
Thanks!
As you know a shunt regulator draws the maximum current all the time, even with no load connected, so you have to think carefully before increasing it.
If you heatsink Q3,4,5,6 and/or go with TO-220 package types for example it should be possible to adjust up to 200 mA. Anything more than that and the board will need a total redesign with more capacitance, larger resistors, etc. It can also be modified to run at higher voltages, though at proportionately lower current.
The S-Reg is designed for low current circuits, specifically an op amp or equivalent based line level circuits like a preamp, phono stage, line driver, and similar. For these applications there is generally no need to have more than 50 mA on tap. Keeping the current limit low means I can get away with a smaller board and simpler BOM.Posted 19th December 2016 at 09:35 PM by rjm
Updated 19th December 2016 at 09:40 PM by rjm
