If I put my notes here, I might be able to find them again later!
The (Zener) Z-Reg Voltage Regulator
Posted 19th December 2016 at 01:55 PM by rjm
Updated 7th March 2017 at 08:11 AM by rjm (BOM 11b2 uploaded)
Companion regulator to the S-Reg. Same board dimensions and connection layout. For line level audio.
Same idea as before rectified 2x12 VAC input, +/- 11 V output. 50 mA max output current unless the transistors are heatsinked.
There is a small amount of over-current protection afforded by R3,4 but do not short the output for all but the shortest of transients.
Eagle/Gerber files attached, so you can go get this made yourself, optinally with whatever modifications you need.
I've use this regulator circuit in my Sapphire headphone amplifier. It's a simple and modest circuit but I feel it works really well in practice as long as the audio circuitry it powers has reasonable PSRR. No feedback means no out-of-band noise or instability, even as the output impedance remains low.
Total Comments 0
