Go Back   Home > Forums > Blogs
Old
Little Big Amp
Posted 3rd August 2013 at 04:55 AM by homeskillet (Journey to the Center of the Circuits of Homeskillet)
Updated 5th August 2013 at 05:34 AM by homeskillet
Hi. Here continues the tinkering continued from the forum post:
https://www.diyaudio.com/forums/tubes...-feedback.html
I took out that EF184 and the plate to plate feedback loop since I read that devices with a more stable performance without feedback sounded better once it was applied than devices that rely on feedback for their very operation. This seemed about right and I was tiring of the sound a bit.
The plate to plate feedback was the only way I could find to stabilize the EF184 and 6550 in this basic configuration and give any reasonable results and wiring it satisfied my curiosity so apart it came.
I replaced V1 with a 12AT7 and wired it in parallel since I figured it could use all the help it could get to drive the 6550.
The global feedback is my first attempt at current feedback. It's basically part of my first attempt at feedback at all.
I...
Click image for larger version
Name:	little big amp Aug. 2, 2013.jpg
homeskillet's Avatar
Posted in Uncategorized
Views 919 Comments 2 homeskillet is offline
Old
Stumbled upon btinterface
Posted 16th July 2013 at 07:32 PM by merlin2069er
Updated 19th July 2013 at 11:36 AM by merlin2069er (adding links...)
I was browsing the google play store one day when I came across something called BTInterface.
Anyways, that free btinterface program led me to btinterface.com where I watched a few of the videos posted. I was immediately impressed with the possibilities. So I bought an android phone, and installed the btinterface app.
I picked up a couple of arduinos (mega 1280) about $12 each, and bt modules, about $8 on ebay, and also picked up some relays to fool around with (about $12) and jumper cables...
BTInterface will allow you to connect to a bt module, then send commands to it. You need a sketch on the arduino to do something with those commands.
BTInterface being a bit limited in what it can do - I purchased basic4android.
So, with basic4android I put together a few screens, on a couple of tabs. The first tab, "Sources" - allows you to edit the name and select a source (these names are saved to an internal...
merlin2069er's Avatar
Views 1247 Comments 2 merlin2069er is offline
Old
Interesting Horn info
Posted 11th July 2013 at 10:55 PM by DougL
In this post the User clams that the Compression driver Atlas PD5V is a derivative of the WE555, which was good down to 100 Hz
https://www.diyaudio.com/forums/multi...ml#post3558010
There was also mention of an AES paper on how to create a phase plug for a cone driver.
Based on Romy's ideas on a mid-bass horn, This might cover down to 200 / 300 hz to transition to a Tapped horn.
Views 1088 Comments 2 DougL is offline
Old
I2S transcoder
Posted 7th July 2013 at 12:57 PM by abraxalito
Updated 16th September 2013 at 01:32 AM by abraxalito (Schematics added, pic of 2nd build added)
Here's a circuit that's been a long time in gestation - some logic that converts I2S from 64fs (32bits per sample) down to 32fs (16bits).
Almost all the S/PDIF receiver chips nowadays output a bit clock at 64fs (2.8MHz for RBCD) because the format has the potential to support up to 24bits. When being driven from a CD player though, there's no chance of any useful information occupying those spare bits. As my interest is to run all signals as slow as possible to keep noise to the absolute minimum, 64fs to me is profligate generation of RF when 32fs will do the job. But only the WM8805 supports this format and then only when software programmed.
The other reason for wanting the slower bit clock is that my LAID design relies on shift registers and the 32fs clock gives me twice as good utilization of the serial storage - no bits are being wasted on zero padding.
This circuit is designed to do the job with the fewest standard logic chips I could manage...
ID:	1110   Click image for larger version
ID:	1111   Click image for larger version
abraxalito's Avatar
Views 3352 Comments 28 abraxalito is offline
Old
Better than a box of chocolates
Posted 25th June 2013 at 06:17 PM by alexcp (My DIY projects)
Updated 25th June 2013 at 08:27 PM by alexcp
Got this today on the cheap - a box of 6N1P-VI, made in 1988, all new in authentic factory packaging. It is likely to keep me entertained for quite some time
Note: the PDF attachment is a scan of the factory three page insert from the box. It is in Russian and contains the pinout and electrical and limiting parameters of the tube but NO CURVES.
ID:	1099   Click image for larger version
ID:	1100   Click image for larger version
ID:	1102   Click image for larger version
ID:	1103   Click image for larger version
ID:	1105   Click image for larger version
ID:	1106   Click image for larger version
alexcp's Avatar
Views 1047 Comments 0 alexcp is offline
Old
High resolution pictures of my projects
Posted 19th June 2013 at 10:54 AM by dvb projekt
From today you will find high resolution pictures
of all my projects at my
flickr
Webside
dvb projekt's Avatar
Posted in Project builds
Views 1730 Comments 0 dvb projekt is offline
Old
The new Red Baron DAC Module V5.0
Posted 19th June 2013 at 10:30 AM by dvb projekt
Updated 12th January 2017 at 10:21 AM by dvb projekt (Stock status updated)
The new Red Baron
V5.0
The evolution brings the following changes
- Jumper for I2S / simultaneous mode
- latest 3.3V attenuator for I2S & simultaneous mode (by -ecdesigns-)
- free running DEM oscillator (by -ecdesigns-)
- additional U.FL pads for I2S & simultaneous mode
- Separate U.FL-GND route to Digital-GND
Still on the module
- Separate I2S-GND route to Digital-GND
- Separate Analog Output GND route
- Separate GND route for active divider decoupling caps to Analog-GND
- Modified active divider decoupling pads for better SMD 1210 caps soldering
- Un-interrupted ground plane
- Direct shunt voltage inputs with shortest onboard traces
- I2S In-/Outputs with shortest onboard traces
- Onboard Grounded-Gate MOSFET Current Buffer I/V Stage
File Type: zip TDA1541A Project - BOM - for The Red Baron V5.xls.zip (9.2 KB, 1678 views)
Posted in Offer
Views 6041 Comments 0 dvb projekt is offline
Old
Reference TDA1541A DAC Modules
Posted 14th June 2013 at 10:51 AM by dvb projekt
Updated 27th September 2013 at 01:27 PM by dvb projekt
TDA1541A DAC Module
- separate TL431 Shunt regulators for each voltage line
- independent voltage rail for the DEM reclock circuit
- I2S attenuator circuit
- shortest possible position for decoupling caps
- separate ground line for decoupling caps
- Ground plane
- 2mm pcb
- Immersion Gold
- green soldermask on both side
- 35µm copper weight
- Board size 125mm x 125mm
in Stock
The price is:
TDA1541A DAC Module: $9
Worldwide shipping: $ 9
Europe shipping: $ 5
paypal fee: 3,9%
Shipping insurance on buyers request!
The Ultra High Speed Buffer Module will be shipped "ready to use",
with three NC7SZ125 chips
Views 2780 Comments 0 dvb projekt is offline
Old
All up (mostly) amp
Posted 12th June 2013 at 01:33 AM by mlise
Here's a shot of the waffle all built up. It's 32" wide and 32" tall with the amps on top, and flat. Typically deeper cabinets sound bedder then shallow ones, but the front to back bracing in this seems to fix it. Mica had an excellent suggestion to hinge it to fold in half. That's awesome. With a vertical hinge in the middle, it's all closed and protected to travel. Ron suggested being able to stack them 3 cabinets high for a wall of sound+ effect. Typical amps have basically a point source. The GD's wall of sound had vertical linear arrays (precursor of the modern line array by 40 years) of drivers. With this amp, you could stack them vertically and horizontally to make a field array. if you got closer, it wouldn't get louder, farther away it wouldn't get lamer. Mwaah ha ha ha...
Views 674 Comments 0 mlise is offline
Old
Ultra high-end amplifier for Stax Electrostatic Headphones
Posted 11th June 2013 at 06:15 PM by dvb projekt
Updated 30th November 2016 at 10:13 AM by dvb projekt
Because my Stax SR-404 Limited is now one year in his box without using...
...i start a new project, based on the fabulous circuit from Andreas Rauenbuehler on high-amp.de
The Transistoramp V4.0
My pcb´s are ready and now i am collecting the parts.
A set of wonderful teflon Stax Pro and Normal jacks, i´ve got from a group buy on Head Case.
So stay tuned...
Views 2598 Comments 0 dvb projekt is offline
Copyright ©1999-2017 diyAudio
