If I put my notes here, I might be able to find them again later!
A headphone amplifier gain calculator
You input the headphone sensitivity and impedance, and it spits out what I think is the ideal amplifier gain.
Even if you disagree (personal preference, difference input levels, etc.), the difference will be consistent regardless of headphone as long as the specified parameters are correct.
The gain value setting is tailored to normal line level input and listening fairly loud with the volume control at 9~10 o'clock. The output series resistance is assumed to be zero ohms.
Adjust as desired, and note that 3~6 dB either way will still be a usable. If your amp has a large output series resistance the gain Av should be scaled up as,
(Routput + headphone Z)/(headphone Z)
Total Comments 0
