If I put my notes here, I might be able to find them again later!
AT-HA5000
This post, about a push-pull MOSFET output stage for a headphone amp, got me thinking again about the Audio Technica AT-HA5000, which is something of a benchmark in its class. The "basic" signal circuit (not a complete schematic, it's clearly missing some ancillary details) is attached below. Probably out of MJ originally.
I think with any circuit like this, the differences are less about the MOSFETs and the operating points and more about the front end and what tricks you do with the power supply. That, and how you make sure it doesn't go up in a puff of vaporized silicon taking your headphones with it.
The Audio Technica schematic has nice old-school Zener regulators, a discrete JFET front end, a long tailed pair + current mirror for voltage gain and "proper" BJT Vbe multiplier and driver stage. Q7 is presumably in thermal contact with Q10,11 providing overtemp protection, and the output has a protection relay (not shown in detail) for overcurrent (overvoltage?) protection. The designers chose to regulate the power supply for the input and voltage gain sections only.
I like it a lot, though I've not heard it: conceptually it looks rock-solid. Though 200 mA through 36 V (7.2 W heat per channel, probably ~20W idle power consumption for the unit) is perhaps a tad excessive. Output power is up at "stupid-high" without breaking out of class A.
Attached LTspice file is a version is bipolar inputs. Work in progress, though it sims out ok.
Total Comments 3
Comments
Hi !
I am very interested in your project. Are there any news ?
Moreover I see your following comment
Quote:.. got me thinking again about the Audio Technica AT-HA5000 which is something of a benchmark in its class ...
Thanks a lot indeed for any information.
Kind regards, ginoPosted 7th July 2016 at 06:49 AM by ginetto61
Updated 7th July 2016 at 06:52 AM by ginetto61 -
Posted 16th July 2016 at 02:17 AM by rjm -
Posted 22nd September 2016 at 03:49 PM by Ropha3r
