If I put my notes here, I might be able to find them again later!
Passive RIAA equalization network response calculator
This Excel (2013) worksheet will help you fine tune the values of the resistors and capacitors used in the passive RIAA network found in any number of two stage tube, op amp, and FET phono stage circuits.
Excel handles complex numbers well enough now that this job isn't particularly difficult, though for simplicity the DC blocking cap (Cc) is left out of the calculation.
Total Comments 0
