If I put my notes here, I might be able to find them again later!
RC filter coupling capacitor calculator
When I need to pick the right capacitor for a coupling capacitor, rather than working out the time constant or 3dB cutoff I just remember the mnemonic "0.1-220" (meaning 0.1 uF and 220 kohms) and adjust the ratio up/down for the resistance I happen to be looking at: 0.22-100, 1-22, 0.47-47.
This amounts to a time constant (t=RC) of 20 ms, and 3 dB cutoff of 7 Hz. The bass attenuation at 20 Hz is half a dB.
If there are several stages the attenuation of all these filters add up, so it can be a good idea to make the capacitance about twice as large. There is rarely any advantage making it much larger still.
Excel worksheet attached. It spits out all the numbers so you don't have to guess.
* calculating the attenuation involves complex numbers. Zr=R, Zc=-i/(2 pi f RC), attenuation (high pass) = | Zr / (Zr+Zc) |. In excel you can use IMSUM, IMDIV, and IMABS to do the complex math.
Total Comments 0
