If I put my notes here, I might be able to find them again later!
A slightly different kind of voltage amplifier
(which is a current feedback amplifier)
Lately I have been looking again for a discrete transistor voltage gain amplifier for line level duty that isn't just another op amp.
I keep coming back to variations on this circuit. It's a diamond buffer input with current mirrors in the mid-section strapped around a voltage divider / feedback loop that provides the gain. This backs out into either another diamond buffer or, in the revised version below, a standard Sziklai output stage which can be more easily scaled up as needed for a headphone amp for example.
An offset bias adjust circuit could be added to trim the output offset voltage. Or use a coupling cap. It's a few hundred mV otherwise.
Circuit gain is R4/R6, approximately. The total value of R4+R6 should be kept about 20 kohms. C1 is a compensation capacitor. Circuit gain as shown is 14 dB, -3 dB at 250 kHz.
As with all CFA, the choice of the feedback resistance R4, R6 is critical. The gain can be varied from about 3 dB (R4 = 10k, R6 = 10k) to the 14 dB shown. Setting the gain higher, either by reducing R6 or increasing R4 runs into problems with stability and bandwidth, respectively.
The simulated distortion figure is -95 dB for 0 dB output into 600 ohms. The PSRR is about 35 dB over the audio bandwidth (at output, for A=14 dB).
Total Comments 0
