I have to admit, I am looking forward to finding out which driver is the Tangband 😉
Is there going to be any objective testing following the result, as with other polls?
Hey
I found it interesting how the width + other times the depth of the soundstage seemed different with some drivers.
Maybe the xo point didn't suit some of the drivers as well as some others?
The 10th is still so far away... 🙁 Maybe you can send the ones that completed the poll the names of the drivers 😉
Regardless, thank you for your effort, time and patience!
Cheers
Same here, two favorites and a close third.I selected my favorite and have two very close runners up.
Cheers
Yes, the measurement data was taken right at the same time the sound clips were recorded to set the levels and check that the XO is setup properly. I will present as usual, the following: frequency response, impulse response, and harmonic distortion.
Outstanding! Much obliged 😀
I have narrowed it down to 3 drivers after lots of listening. All three are very close and it's actually amazing how good all three sound. Not sure how much progress others are making but it is now going slow.
I have actually gone backwards adding another driver back into my top picks. Back to a top4 drivers now. All sound excellent each with subtle strengths. Maybe a top pick is percolating to the top though.
This is how I found the poll, 2 or 3 were easy to eliminate for hot responses (despite that with correct filtering that could be mitigated greatly)
3 sounded far more laid back "straight out of the box".
I'm fairly sure I eliminated my budget fave the FRS5X for being hot, though I have no intention of using it without a lowpass.
The last 3 really were a tight group, in particular the last 2.
I agree that the last 2 or 3 (in my case) are now in a very tight race. In fact, listening to them over and over and cannot quite decide. One has a particular sense of more "fullness" in the lower register. The other two seem to have more "snap" in the transients though, however, they are accompanied with a bit of a "glassy shimmer". The shimmer sounds pleasant enough on some tracks but I wonder if that is a natural sound and would I get tired of it. We have lots of time left but it is getting tiring to go over and over it.
That's why I deliberately made the process quick. In my experience, when listening for differences, things tend to get "all over the place" when it takes too long. As if my hearing gets unstable or something. Luckily, the best two stood out quite clearly, and it took only a few repetitions between those two to pick my favorite.
This reminds me of a test I did some years ago with the help of my wife. I was responding to a challenge on "ground side electrons" or something of equal silliness. The mod to the CD player was simple: attach an electron tube with all pins tied together to the ground of the CD player and listen for a difference. Of course, any sane person will tell you that there should be no difference provided the player is made anything near half decent, but I did a blind test nonetheless in an attempt to silence the debate.
I (un)soldered the tube socket to the CD player's ground, while my wife was listening on the other side of the door using my headphones (HD650) connected to the player's headphone output. She couldn't see or hear me, and I checked beforehand if it was possible to hear me solder through the headphones. It wasn't. I played the same set of clips a couple of times, while I rolled a dice to determine if the clip was to be played with the tube in or out of the circuit. Initially, the clips played with and without the tube sounded the same to her, but as the test progressed and she was doing more and more her best to spot a difference, she noticed that her perception started to change haphazardly, both during and between clips, up to the point that she quit because her hearing obviously started to play tricks on her. So that's what she reported back to me. Her observations did not correlate with the tube being in or out of the circuit.
Although I didn't expect the test to yield anything, it provided this little revelation nonetheless. Many differences between gear are simply heard or exaggerated because we try too hard, and then a little bit of expectation bias or a very subtle clue are all that's needed to tip the scale in a certain direction. The process of desperately trying to hear stuff makes us hear stuff. In a sense, the ear and brain give us what we want, and by doing so, they send us into the woods. I think this is normal behavior for human hearing, surely my wife and I aren't the only ones susceptible to this.
To make a long story short, here is my tip. Try to pick your favorite quickly, cast your vote and be done with it. Doing the test over and over again doesn't necessarily make the outcome more reliable, it probably just messes things up.
I agree with Timpert also, I have difficulties if not deciding relatively quick. But we are all different, aren't we😛. I have friends that go on for ever before deciding whatever is on……..
But I think also for me, it would be more obvious if I could have extended periods with speakers, especially when differences aren't so big. But this isn't possible for me, so a massive thanks for your work, xrk!!😀
Peter
Peter
My test method consisted of first eliminating the drivers which had obvious linear distortion problems - a few of the drivers had a zinger near the top end of the freq response which 'enhanced' some tracks but would sound awful on others - I hate using subjective buzzwords but 'shrill' or 'nasal' is probably the best way to describe it. One driver had some holes in the midrange response, so I eliminated that one as well.
The next elimination was harmonic distortion on the lower end. Again, some tracks would be 'enhanced' by excessive distortion which made them seem more bassy while comparatively the more linear drivers sounded a bit weak/thin, but then on another track the non-linear drivers could produce slightly flabby sounding bass or sound a bit 'honky'.
That left me with just two drivers. It was pretty close and i had to do 3-4 passes of each track but I eventually picked the one which sounded like it had the most balanced freq response - consistently sounded most like the tonal balance of the original recording. Perhaps not the most exciting driver for any given track, but it did the least wrong overall.
Different with me. One possible reason why too long can mess up everything is when there is BIAS in the judgement, such as "Okay I prefer driver Z, what driver is it possibly? Hmmm it looks like a Peerless! No way! It's a cheap driver with false treble! I will change my preference to driver Y!".
In general, for me, more time will only add more information and accuracy. Especially because for me the difference is so obvious (and can be proven with blind test with 100% accuracy). What is not so obvious, is to pick preference.
At first listening round (not even finishing the music with bad drivers) I can quickly removed 2 drivers (fatiguing distortion) and had 2 drivers stand out because of (1) "neutrality" of one driver (2) "sweatness" and added 2nd harmonics of the other driver (which makes guitar instrument easy on ears and vocal becomes sweeter than it should). If I had to make decision within those few minutes, I would have picked those 2 drivers (even tho I knew that 2nd order distortion will bring some consequences).
Only with further listening I understand the different between each of the drivers. But still, my #1 preference is decided by a bit of subjectivity than objectivity. Objectively, it is not the cleanest, but subjectively, in my ears the tonality is more correct. It is hard to know the correct tonality of a guitar keys because I'm not a guitar player. But Eric Clapton male voice is special imo, and I felt one driver can do it tonaly better so that is my #1 preference. But I haven't voted yet.
Judging the correctness of tonality is probably not an easy job (needs experience), and it works only on limited frequency bandwidth. I might want to download other musics to make sure that I picked the right preference between the top 2 or 3 drivers.
I will also need extra time if I want to compare the non-linear distortions between the top drivers. But I found that in general, the average drivers non-linear distortions are better than I expected. Probably because of the high XO frequency and the good phase behaviour of the crossover. So I think I don't need to go very analytical here.
The point/conclusion is, more time will only add more accuracy for me.
Yes, I know that. But I have avoided analyzing the bass because the crossover is quite high so that the bass is more of RS225 responsibility. That's why I didn't pick the last music (clip #6), which is probably the most challenging, especially in the bass.
Haha track 6 is misleading anyway.
Its that trademark R&B sizzle factory vocal track which makes every word sound like its been whispered into a megaphone.
Y'know that Mariah Carey sound hahaha
Haha, okay may be I don't need to try it. I downloaded the 4 reference clips and I found that that music was so disturbing with my laptop and headphone. So it is from the recording then. But what's wrong with Mariah Carey sound?
I believe that a characteristics of a good speaker (per my criteria) is that it should be able to show the quality of great musicians and singers. And I believe Mariah Carey was a diva, or at least famous for a reason. Ha! May be your speaker is not up to it! 😉
Hahah I don't like or dislike Mariah Carey, she has talent for sure.
Her vocals just always seem as though recorded with a lot of treble "air" making her sound sizzle and very "breathey".
- Full Range
- A Subjective Blind Comparison of 2in to 4in drivers - Round 3
