Hi, here is the sprint file and the circuit with numbered transistors. Maybe someone finds it useful.Nice work, with 1k trimpot you can set THD to minimum.
What is PSU for preamp?
The power supply in the picture from the previous post is a standard circuit with LM317 / 337. However, it must be replaced with one with a larger heat sink for stereo amplifier.
regards Olaf
regards Olaf
Thank you for this nice pcb, and thanks for made and test this circuit.
Tone Control
Hi.
Unfortunately i can't set the bias. Voltage of 33R/5W is about 0v.
base of mje340/350 and Bc547/557 have about 45v Dc.
is it ok?
regards.
is it ok?
regards.
Maybe i vas a litle late vith the tread but here is my AX-11, best amp in the world 🙂
Transformer is recycled, 4x12V 8.6A from halogen light power supply, gives 2x36VDC after bridge, rectifier is simple, KBU806 and 4x4700uF per rail, vas transistors MJE340/350, drivers MJE15030/15031 and outputs 2SA1943/SC5200
Sound is great vay better than most comercial amps i have and better than LF55 that i was builded previously.
Thanks to Mile for help an cheers to all
Hi, looks very good. AX-11 has a super sound. Could be better if you twisted the cables. How did you attach the power transistors?
regards Olaf
regards Olaf
Thanks to Mile for help an cheers to all![]()
Nice work.
Cheers
regards Olaf
maxxaudio use my metod to attach power transistors.
Tone Control
Hi Mile,
Thanks for the Tone control circuit. I am building an all APEX P30 preamp. Included will be the P30, MM3, A class PSU and this tone control circuit. I am not sure how the tone circuit and the volume control connect with the P30. DO you have a schematic showing where to integrate the tone circuit?
Thanks, Terry
Ax-11 layout files
Can you pls post the latest/improved layout for Ax-11 please?
Sumesh
Sumesh
Hi Mile,
Thanks, Terry
Nice work, connect tone control input to output of P30 input buffer and tone control output to volume pot input... A class PSU can not give current to supply all this circuits.
What is the A class PSU? Where can I find that?
regards Olaf
Hi Olaf,
Here it is
http://www.diyaudio.com/forums/power-supplies/164365-class-preamp-psu.html
reg
Prasi
Thank you very much 🙂Hi Olaf,
Here it is
reg
Prasi
regards Olaf
- 100W Ultimate Fidelity Amplifier
