Best pots for audio ?
683973d1527670301-pots-audio-ctrlvol_att-30-pos-jpg
this type of attenuator can become very noisy in an area close to transmission towers. It is a real antenna!
Why should it be so ? Since ten years I am using an other version having six channels, six positions, unbalanced inputs, at the output of BSS366 processor.
All the inputs and outputs are non-insulated RCA sockets.
It is mainly set for an attenuation between 20 and 30 dB.
Neither with it nor with the attenuator on the photo, I ever encountered problems with parasitics or noise.
I would recommend something like this DACT Type 21 Stepped Attenuator / Volume Control (Hi Fi Grade) * D shape Shaft * | eBay This is the detailed view of it eBay
Don't be put off by the cheap price. I got one for my preamp a few years ago, I'd never been happy with any pots I'd bought (mainly due to channel imbalance). I was a bit skeptical that something this cheap would be good, but I couldn't be happier 🙂
Tony.
+1
I use these in my m-c phono stage, 1 stereo attenuator as a gain controller and one stereo attenuator to provide variable cartridge loading. They have worked flawlessly for 2 or 3 years.
also from my view the best solution (looks like military grade janco- or electro-switch) together with rotary switch type 04 from ELMA. Also good P&G with oil (used e. g. from Jeff Rowland in his Coherence ONE), but since a long time not longer available).
Check out also this thread
https://www.diyaudio.com/community/...kd-and-vishay-and-more-whats-your-fav.153841/
very many dead links are available by webarchive in most cases.
Reactions: Joel Wesseling
