100W Ultimate Fidelity Amplifier
Thanks for the concern,
Actually i was a little heartbroken today and not in a mood to do much trouble shooting, however I won't leave him without making a good boy. Once i reach home i will take him up.
Regards.
Sorry to hear you had some troubles. I'm sure here are some people watching your work :) Weekend is coming, everybody will get better, I hope.
dc6
Mr. mile could you tell me if this is what I am doing
  • BOM-apex ax14_total new_2pairs_rev1_sch clean up.xlsx.zip
Hello Chris,
Here it is..
regards
Prasi
BOM's can be a nightmare trying to keep track of which one goes with which amp or version of amp.
I choose the pcb file name carefully and then the pcb file name comes out on the printed BOM and also on the pcb.
Don't do what I did and had a schematic and pcb open at the same time.
I closed own the pcb but not the schematic.
I reannotated the pcb and sch then saved the sch making the sch out of step with the pcb. Luckily it was all backed up.
Apex A40
which one is the correct scheme with the layout for the resistor value, 470ohm or 470k?couse i have get scheme there 470k for R set DCo,but on the layout there are 470r.
I also have a problem with the bias going up, also DCo which is unstable,
My supply uses 40VAC,
my bias sets 10mV on the R emitter but goes up continuously,
My DCo sets close to 0V but goes up again to 100mV more.
Please help to make this A40 stable.
Thanks for the suggestion Nigel,
Eagle software that I use will have the same file name for sch, layout and also any BoM exported from it. It immediately gives a big warning when I close either sch file or layout file.
But , I should start denoting version number and date in layout /sch and BoM.
regards
Prasi
the tests are input in short and without a speaker?
hi all. i want to make p30 pre amplifier for a40 but i could not get pcb layout. can any one give me pdf of p30 pcb printout?
I built both versions but this is the one I used in my preamp.
These are for toner transfer.
  • P30 AMPLIFIER APEX ALL.pdf
  • P30 AMPLIFIER APEX BOTTOM REVERSED.pdf
  • P30 AMPLIFIER APEX SILK SCREEN MIRRORED.pdf
I checked and I actually used a modified version of the above layout. I really just simplified a little as Alex had designed it with two different sets of holes for the resistors and caps. I removed the extra holes to make it easier to etch and drill. I am adding those file here.
These are also for toner transfer. I you need photo sense files let me know.
  • P30 as built componants.pdf
  • P30 as built toner.pdf
thanks for files.
