4th Annual Vancouver Island diyFEST 2007
planet10 said:
LK48 used as donor. Push-pull EL84s strapped in triode running Class A (cathode bias). Front end is based on El-cheapo ECC81 LTP but with the diyAudio CCS. Power supply is dual mono after the 1st cap (ie splits to a choke for each channel). No feedback.
This 4W amp has the best bass (within its power limitations) of any amp i've heard recently. A real gem.
dave
Dave,
I couldn't agree more. I've got an old Scott 299(a) that's stock and it's pretty nice, but every modified 222 I've ever heard has been superb. They knew how to wind 'em in those days and those small tubes can really make music.
Chris,
Don't you think it's time to make some cosmetic additions to your amp? It really is worthy of some nice case-work.
Best Regards,
TerryO
The 4" Hemps sounded really good.... the larger ones where put on out of phase at one point and sounded.... out of phase.
I didn't listen to them a lot after the phase was fixed but the B200s sounded really good. So did that Korean driver. All of them needed a sub in my opinion.
Re: Re: Hemp 8's
leadbelly said:
Although Stu said he was happy with the Hemp's in question, which were his, in the box he has them in.
It will be interesting to see how he likes them now that i've renovated them.
dave
Re: Re: Re: Hemp 8's
dave
yes, with phase plugs and C-37 treatment, these could be very interesting.
Stu any feedback on that yet? - curious minds want to know - and for those of us who didn't get a chance to hear the discussion, in what type of enclosure will these find their home?
Kevin Haskins said:
The 4" Hemps where not OBs though.... they where in a set of Scott's cabinets.
The 4" (108mm) Fostex with the cone that looked like you stepped on it sounded pretty good too. Especially with girlie music.
Kevin,
Are you thinking of the 3 inch Fostex Sigma's in the double horn that played out on the deck? I remember that you and I both thought that it was absolutely stunning with female voices. I am at a loss as to what the Radio Shack equivalent would be however.😉
I'll take a look later this evening and see if I can find the model #.
Best Regards,
TerryO
dave
And here's the surgery in progress! 😀
That was fascinating to watch. Skilled hands went at lightning speed!
OK folks, here's some more pics from Geek now that he's rested 😉
Speaking of the Hemp 8", here's the guys prepping the baffles:
Then we need some clean power for OB:
Jess had caught me taking a pic of my line buffer earlier. Here was the resulting shot:
Scientists are still pondering the mystery oil in those cables. Maybe we should run sub-power through them to check for combustibility :clown:
Another shot of Jess' equipment:
What'd you think? ..... Get your minds out of the gutter 🙄 😀
The Sigma's definately sounded as different as they looked ... in a good way:
Back inside, a proud papa shows off his latest babies:
15Lbs, 7 oz ...... for the crossover that is:
Sourced by a very interesting and cool device, the Squeeze Box:
