What about making a compression cavity there? Instead of a moving wall only some apertures in a fixed wall and the moving diaphragm just beneath. But I have no idea of the bandwidth reachable this way. The apertures could be positioned closer to the throat, I would think.
Where is the drawback using a coax compression driver? They do combine both sources in the pure pressure area before any expansion. There are some good out there and 400Hz easily reachable as I showed with my dcx 464. Of course a free choice of hf and mf driver would be nice. But is the benefit worth the work?
It's called DIY, an enjoyable activity, for some ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Based on what I've seen, the HF outputs of coaxial compression drivers still leave a lot to be desired. I would be interested in how clean a MEH design can be. The moving wall seems like a good idea to me (if not moving too much), and a moving wall beneath a thin perforated cover perhaps even better. It all comes down to how clean HF response it would provide. If not better than the other solutions, than it's probably not worth the effort. Are you not interested to try?
Well the sad truth is that in the end one often spends a lot more than if bought something "good enough" right away. But that's a too simple considerationFor diy me personally its a challenge to squeeze as much performance out of cheaper components and experiments.
Besides, with 3D printing at hand, it can all have pretty wild shapes. I already have some fantasies... ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- To me the "task" now is how to improve further what I already have. What's the next step... A better phase plug, a MEH? Maybe it would be a coaxial CD, I don't know.
Simple rule is that they should not vibrate and make sound, although perhaps vibration doesn't matter if the transportability is priority number one. Just "regular print" I did vibrates audibly, and had to dampen it. Perhaps you can have backup plan: in case your foldable / inflatable waveguide has too much of a problem with it, there is possibility to add dampening somehow.
So we have super stiff/damped Magico that some don't like and BBC approch of vibrating front panel but rest walls are damping the front. Which one you like more? You can print now ABS+GF or hard TPU and tell us.
https://eu.store.bambulab.com/en-pl/products/abs-gf
...of course 🤣🤷♂️🥳Are you not interested to try?
It's also nice to do it because nobody has done itIt's called DIY, an enjoyable activity, for some
- Acoustic Horn Design – The Easy Way (Ath4)
