600VA is a manly man's trafo. ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have put these in series before and it powered my M2 with no hum vs a linear trafo which has hum. The output is electrically isolated from earth ground so you can series them to get dual rail supplies.
Amazon.com: SUPERNIGHT AC 100-240V To DC 24V 5A 5.5x2.1mm DC Output Jack Power Supply Converter Adapter for Led Light Strips: Computers & Accessories
I will try this with my current P2P proto and see if I can take it to 2amps.
600VA is a manly man's trafo.![]()
And heavy, ~12lbs IIRC.
Maybe a bit much overkill.
Looks like general consensus for a voting sample of 3-5 people is thicker boards.
Ok, I think I can do a group buy for this amp at $22/pair plus $5 shipping in USA and $10 Canada and $15 everywhere else. Boards will be 2mm thick, double thickness (70um) copper traces, ENIG gold finish, blue color with white silkscreen.
I think we have about 5 people expressing interest so far.
GB for Alpha 20W interest list:
5 pairs so far
Pinocchio - 1 pair
6L6 - 1 pair
bk856er - 1 pair
Vunce - 1 pair
Pcgab - 1 pair
5 pairs so far
Will there also be boards for the higher wattage system?
David
Yes, coming soon. Note that that one has not been tested at the prototype stage yet.
GB Status Update:
Pinocchio - 1 pair, Invoice sent
6L6 - 1 pair, * Need PayPal address *
bk856er - 1 pair, Invoice sent
Vunce - 2 pairs, Invoice sent
Pcgab - 1 pair, Invoice sent
jwjarch - 1 pair, Invoice sent
vvs07 - 2 pairs, Invoice sent
jacques antoine - 1 pair, Invoice sent
GnuB - 1 pair
GnuB - 1 pair
X, is there a disadvantage to using two, one to each channel, and not running them in series?
- Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
