Amateur with Tube Amplifier
You can try a variable resistor
I will try with 47K, 100K, 200K feedback resistor. will low FB effect open wide rang freq or what?
There are variable resistors with screw adjustments that can cover the resistance range you are looking at. For most PP amps , depending on the quality of the output transformer, you will seldom see the FB resistor of more than 33K ohm. If you are considering using a pot , don't use analog type, get a linear pot.
