Don't find it on your site?I created a follow up soundcard interface using isolated 5V to +/-15V, TPS7A49/30, OPA1656 and INA1651. This module won't be a bottleneck for MOTU M4.
SMT parts assembled by JLCPCB (attached bottom pcb pic).
D
Deleted member 148505
I only ordered 2pcs for prototyping and for its parts, my orders for both LCSC and Mouser got delayed. So maybe 1 to 2 months before I release it.
D
Finally our mouser order has been shippednext batch of Sylph-D200 will be rolled out next week.
Yeah, Mouser has had problems with both supply & fulfilling orders quickly recently. Digikey seems to be fine but are out of stock of opa1656 op amps as well (like Mouser).
Pete
On the other hand, Digi-key charges very high shipping costs of 21 euros in Germany if the order value is less than 50 euros. In contrast, Mouser always sends its parts free of shipping costs. For me, that's the reason to buy from Mouser. I'd rather wait two days longer.
Plan to drive 4-way open baffle speakers on a chain of PC, 8-channel audio interface and TPA3255.
The audio interface is an octo DAC8 Pro that can deliver 4.1Vrms maximum. Should I turn down the voltage on the octo DAC so that the SYLPH-D200s are not overdriven?
D
No need since you need 4Vrms for balanced input if you enable PFFB.
D
Pete
My Mouser order (using UPS courier) has arrived last weekend. However my LCSC order with DHL courier was held by Philippine customs for a week now, looks like Covid surge problems.
4V? Website says 2v, unless that figure is for single-ended and single-ended is more sensitivity somehow?No need since you need 4Vrms for balanced input if you enable PFFB.
Please confirm the 4Vrms for the SYLPH-D200 again, as the website says 2Vrms maximum.
Input sensitivity (PFFB disabled): 1V RMS
Input sensitivity (PFFB enabled): 2V RMS
Why are the values different for PFFB disabled and PFFB enabled?
D
2Vrms for SE/common mode signal, 4Vrms for differential full scale signal.
The module is shipped as default SE (unless requested)
PFFB has around 6dB negative feedback so it has a lower sensitivity.
D
Hmm no, with PFFB, the gain will be reduced so you need 2Vrms for SE and 4Vrms for balanced (2Vrms Hot to Gnd, 2Vrms cold to Gnd, 4Vrms full scale).
Without PFFB, you only need 1Vrms for SE and 2Vrms for Balanced connections.
You can reduce the gain by changing the resistors of the inverting opamps.
Thank you for the quick answer. So the variant "without PFFB" runs with 4Vrms.
For the variant "with PFFB", one volt less applies. In this case, does something have to be changed in the SYLPH-D200 at 4Vrms?
D
@JLester, I want my SYLPH-D200 3251 amp board to be Balanced 4Vrms with PFFB implemented, could you configure that for me?2Vrms for SE/common mode signal, 4Vrms for differential full scale signal.
D
Yes, TPA3251, we will configure it for balanced input.
D
RogerCl - should be like this:
Input sensitivity - SE (PFFB disabled): 1V RMS
Input sensitivity - SE (PFFB enabled): 2V RMS
Input sensitivity - Balanced (PFFB disabled): 2V RMS
Input sensitivity - Balanced (PFFB enabled): 4V RMS
Yes, this is correct. Thanks!
- Vendor's Bazaar
- Amplifier Modules and PCBs For Sale
