Anyways ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I can see this thread hit 200 pages in no time!
Can i make a suggestion ??
Can we Wiki this info for future people saving them the trouble of having to read through all of it.
Including the info about the FIFO, clock boards and Input board
Then Ian can append it to his signature for everyone's viewing pleasure![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This would clean up the thread and keep it on track as most simple questions would be answered
Wiki is a good idea, I would contribute to maintaining/setting up a wiki for this project on one condition, that Ian is happy for it to be recorded in that way.
IF Ian is happy for the community to maintain a wiki on his project then I think it would be a great initiative!
FWIW I think the wiki could be used as a simple index to the important bits of information in the thread and arranged by 'sub-project' ie 1 section for FIFO information and a separate section for different XO boards, isol boards etc etc and would act as an index of links to Ian's (and other 'experts') post's with information that is already in the thread.
And #2 LOL
On the Input Board...
Are the inputs selectable or are they all "bridged" ??
I'm looking at the idea of building a preamp.
If they are selectable by the means of i2C or switches/jumpers I'd be interested to see if it can be expanded![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm no good with boards so I'd rather compensate someone that could do it in less time / effort rather than me
Was thinking double the inputs of the Current one would be a decent start for a preamp for the digital section
And #2 LOL
On the spdif board the inputs are selectable.
EDIT: I see you wrote some more
Well I believe the spdif board in current state has a push button that cycles through the inputs, not an extendable protocol, but very functional. I haven't used or have any intention of using the spdif board (I don't need more than one i2s input) Thinking out loud here - I wonder if the extra i2s 'backdoor' input could be used to have 2 boards stacked together somehow?
I have started a draft wiki offline and will only click the 'Publish' button if Ian gives the nod of approval
I'd rather just have more inputs on the board and keep the single I2S coming off the board that way the digital signals can be fed into a I2S Bridge ( Open - FIFO On, Closed - FIFO Off ) of some sort before it hits the BIII
And #2 LOL
S/PDIF board function as selectable input, and provides several outputs as well. Input is selectable by switch, so that you could select between optical, coax, AES/EBU or I2S input. I am using it in that manner. Expansion connector is provided so that you could have switch and LEDs on the front panel. Switch circulate between inputs and is not selectable by other means. The only problem I have is that current is way to low for LEDs, and so they are barely visible. There are ways of solving this, but I just did not bother doing it, it is very low on my importance list. Other than that it works perfectly without any glitch so far in my set up.
If you need more inputs, you might need to do it different way, I am afraid. Most likely you would need to have some other unit where you would handle inputs and than you would send out I2S or S/PDIF to the FIFO board.
I'm planing to use HiFiduino with a 5" touch TFT for the interface along with 2 push-rotary encoders the push function on the input selector will turn the unit on and off while the push function on the volume control will act as mute.
Now wondering if there's a I2S capable multichannel DSP in a DIY form out there...
Being a bit sneaky i can easily incorporate HDMI switching as well by canibalizing an ebay HDMI Switch with spdif output for the audio for a cheap way to interface HDMI Audio and gain HDMI Switching![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyways
Another good idea! +1
Ian
As Ian has indicated is approval above I've posted a skeleton here - Ian's I2S FIFO Project - diyAudio
I'll start adding some content over the next few days. I know very little about the spdif board or the PCM adapter so hopefully others might contribute to those sections!
Chris
Chris
Adrculda, just so you know those switch convert normaly anything higher than 44.1 to 48khz. I know I have one ;-) Not the exact same model but close
http://www.monoprice.com/products/p...011002&p_id=6415&seq=1&format=3#specification
If not specified explicitly I would not hope to do 96khz 2 channels or higher with this kind of HDMI switch...
For only $67.50 each when QTY 50+ purchased - 4x2 True Matrix High Speed HDMI® Powered Switch w/ Remote w/ 3D and x.v.Color™ support | Auto & Powered HDMI Switches
Thanks for the heads up...
Back to the drawing board LOL
will wiki have schematic? ![devil_y :devily: :devily:](https://files.diyaudio.com/forums/images/smilies/nicedevil.gif)
wiki is a great idea, in my experience relying on people to read the wiki..... doesnt quite work as planned, but it will provide an easy 'read the ******* wiki, page X' and overall the thread organism should mean a better informational resource than posts repeated over and over again in the thread by a small circle of users.
HDMI to FIFO
Update: just checked, if I plug my source thru my HDMI switch I'm limited to 44.1khz and 48Khz... If a plug my received with no switch my NVIDIA High definition audio card detect 96khz availability
An even if you send Dolby True HD on the HDMI channel the SPDIF out will probably only send 2 channel 48khz...
One great HDMI compagnon for the FIFO would be the HDfury HDMI to component adapter.
Chris
Thank you so much Chris. I appreciate your efforts to the community!
Now I'm focusing on the Si570 project, I know a lot of friends are waiting for this small board (just got V2.0 PCB
Any help to the wiki is more than welcome
Ian
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
