The reason I am asking is since Pass and Wayne selected to remove degeneration resistors and use CFM at the source and experienced better dynamics together with better slew rate*, that this would be a good indication of what to do ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But like you have mentioned several times, one have to look at the whole circuit and I understand that. It would be fun to learn the difference of VFB and CFB on the same amplifier, so I guess the only way to find out is to do.
* 100V/mS for INT-25 and XA25 compared to 50V/mS for X and XA.8 series
I'm wondering if I could get away with 4U-sized sinks for the SIT version... Adding some nice and quiet Noctua fans if need be? I think I have some extra fans lying around at the moment lol.
Sorry if I missed it, what's the ballpark ETA on boards? Please count me in for a pair, Mighty ZM!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I just want to interject with something.
The Onsemi NSVJ3910 (Vds 25V) is $0.43 per pcs if you order 100 pcs via Mouser. With those prices, you can match to 1% tightness.
That was it, that was all I had to say. Now back to the regular schedule![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Read the full JFet noise test report: https://www.mvaudiolabs.com/diy/modern-jfet-noise-measurements/#setupNSVJ3910 seems like a good match for 2SK170. Almost identical noise spectrum’s, but it has twice as much trans-conductance (22 vs. 40 mS) and five times lower input capacitance! (6 vs. 30pF). So a huge overall improvement over now legendary 2SK170. Also, negligible NSVJ3910 input capacitance makes this part most attractive in terms of paralleling then any other JFET measured here. Just a word of caution – it was the ONLY part that decided to be ~350Mhz oscillator instead of amplifier in my measurements. So care must be taken to isolate gate appropriately for the application.
A tiny follow up on post #529. The NSVJ6904DSB6 is a dual package of the NSVJ3910. The NSVJ6904 is a CASE 318BD, this happen to be the same size as the 2SK2145BL in the 2-3L1C package. The difference is the source connection, which is flipped on the NSVJ6904, which is sad since it would have been drop in. Such is life. The fix is easy. Use a 6-pin footprint and create an extra track such that Pin-2 of the Toshiba/LSK part is connected to Pin-5 of the Onsemi part, now both packages have a source trace available.
Oh for sure, the Tosh is a no brainer. Yamaha is using those parts (2SK209 single variant) in their top amplifiers and I think Accuphase also use them, but variations is good to have and know about and if we can have yet another FET besides Toshiba and Linear Systems, even better.
- Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
