dunno
don't have neither greenies to spare (for them ) nor time .... or will
is that curse or luck - not needing more than regular FW wattage frame ........
Yeah, I understand.
I love the ACA, but this one has balls, plus decent damping factor, so I am curious to see whether it performs to my liking as I suspect it should.
After that I'm just going to focus on completing all my dumb amp ideas.
The beast stabilised at 2.13 Amps (at Vgs=4.75V, Vds=20V)
I've increased Vgs to 4.80V, I'll go back and check it later (need to sleep)
I'll repeat later with Vds of 27V to 28V.
https://www.youtube.com/watch?v=ncFCdCjBqcE
Hi 2picodumbs,
Is the part still alive.....))
Yeah it's still alive.
Not to worry though I have 10 in total.
Had to sleep, only got 2 hrs sleep the previous night. I'll try and do more today.
Just a side note. These things are really excellent at transferring heat.
Maybe a silly question, but is there " thermalgrease" between transistor and heatzink ?
I have tried both.
These things are electrically insulated so no need to worry.
Just to be sure, I do not mean electrical insulation, I know that these transistors are insulated but I am always using a small amount of thermalgrease between component and heatzink just to be absolutley sure that maximum heattransport is secured.
Sometimes is "strange behavior" in components and circuits depending on insecure heattransport and instabil/unlinear temperature variations.
The point of the thermal grease is to improve the contact between the part and the heatsink, probably a pretty good idea here.
It's never a bad idea except if it is too thick.
I tend to derive the best solution through experimentation based on real data.
- BAF 2015 Coverage
