When do you think we might enjoy it?![]()
Very soon. I made one small change to the board after making the prototype. Those boards should be here in the next week or two.
I asked for the capacitor type to see if it is possible to use a high quality film and foil or polypropilene capacitor. Seems that people will have to go with electrolytics...
Actually you can use whatever caps you like, and they do not have to be mounted on the PCB.
We will be supplying 100uF Nichicon Muse ES caps for the coupling caps in the Legato kits. We didn't pick film caps for the kits for two reasons: 1) they are really big and would not mount on the board anyway and 2) everyone has a different favorite (too much personal preference). So, we picked a really really good EL cap that sounds fantastic. Upgrade at will.
Hi Russ/Brian,
Perhaps I've missed it somewhere in the thread, but what is the output impedance of the IVY3?
Cheers
It depends. If you use the supplied 22.1R resistors then its 22.1R
When I setup a DAC for only headphone Duty I use jumpers. Otherwise i use the 22.1R.
Hi Russ/Brian,
Cheers
Link to calculate input & output impedance:
mh-audio.nl - Home
Is the legato considered an upgrade to the IVY?
No, just a different approach. Some people will consider it an upgrade, some will consider it a downgrade.
I see it this way. They are both extremely enjoyable, but definitely different.
One very cool thing about the discrete cct is you give up almost nothing in terms of DNR. It is extremely low noise.
The lack of GFB will be very appealing to many folks. Also appealing is the extremely low distortion. Now its not going to be quite as good in this regard as the IVY-III but it is very close.
My gear is not good enough to measure it, but I will have it measured.
Here is the simulation FFT. My ears tell me its pretty accurate.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Russ,
Will there be any way of using the Legato together with a Buff II in dual-mono configuration without adding also a Ballsie stage?
Thanks,
Nic
Absolutely, and in fact I have to correct myself. I did some further checking after my post earlier about the same thing. THD should *not* suffer in this configuration, but I am not thinking it will be any better either.
Cheers!
Russ
Dear Russ,
good news! The reason I asked earlier was that I thought that twice the output current from a mono configured Buf2 would cause linearity issues with the transistors used.
THD is not that relevant. It does not tell the whole story. Far from it.
Regards,
Regards,
Cheers!
Russ
Dear Russ,
Regards,
Oh it definitely does have some impact, but not enough to sweat over.
Any idea about the delivery of the audio controller + femto? I'd like to order it along with a set of BII boards + other things to build a dual mono DAC/Pre. Plus would it be possible to control an OTTO + Mux combo?
That way I could use I2S from the Mux for SPDIF, Toslink & possibly AES while also adding an USB to I2S converter (a M2tech I hope to buy through the current group buy).
As a note: if the software isn't tidy enough yet, I'll finish it myself. One of the advantages of being a software engineer. Only designing those PCBs + collecting all parts is a bit too much work for my taste. Sound familiar?![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hi Russ,
Speaking of impact, how have you been coping with the floods (and I don't mean the requests for updated designs)?
Here is the Legato.
I am really enjoying it.
Is this cousin DC coupled ? Any chance of seeing the schematics ? And finally, an estimated time to delivery ?
- More Vendors...
- Twisted Pear
- Buffalo II
