Build This MoFo!
thank you.
I want to thank all the people who have helped me in my build.
It is a very nice and simple amp to build.
bass is surprisingly good driving Markaudio 12 P full ranger.
The sound is much more engaging and toe tapping . It sounds much better than many of my more complex build.
My major problem is heat management . I have to use fan to achieve a bias of 1.8 amp. Power supply is 24 V dc.
Is there an audible sound difference with a bias of 2.5 amp ?
I did consider the fan blowing towards the fin or the top of the heatsink.
The problem is the difficulty to mount the fans .
Any suggestions ??
i am considering whether to do another build with a 2X size heatsink
Hi kp93300,
Dell CPU coolers work great, I’m running 2.5A bias without a problem 😀
Regards,
Vunce
Vunce, what are the dimensions of the heat sink ?
Hi Kp93300,
Dell FD841 dimensions
Aluminum fins: 88x75x85(w,d,h)
Mounting base: 88x65
Overall height : 160mm (base to pipe tip)
You can find these used units on marketplace’s similar to eBay and such, they do not include a fan, you have to add that yourself. The other solution is to buy new aftermarket units where the fan is already connected to the CPU cooler. Power is from a 12vdc source feeding a PWM fan control module w/temperature sensor.
The Noctua Nf-a8, 80mm fans always stay on the slowest speed and are near silent.
It’s not a classic Class A ‘look’ and you have to get creative to mount the MoFo board but, even with the additional circuitry it’s more economical than big heatsinks, saves a ton of weight and cooling performance is amazing!
Regards,
Vunce
Yes, with good fan cooled CPU heatpipe cooler, one can run a Class A at 150w dissipation (assuming one is using a MOSFET rated for 450w, 150w is only 1/3rd so no problem) and fins stay relatively cool. It's quite amazing what modern thermal engineering aimed at server racks can do vs natural convection based on massive slabs of aluminum fins and slow rising air buoyancy (the Grashof number). Imagine a MoFo at 37v and 4.25amps. 😀
The CPU cooler that Vunce is using is an excellent one with a very large copper surface that can handle two MOSFETs side by side if needed.
That is one badass looking MoFo, right out of a Mad Max movie!
726075d1546401150-build-mofo-513abf01-30a5-4ae3-bbdb-80c8f904b97b-jpg
Hi guys
Found these FD841 on eBay but wonder why one of them doesn’t seem to have copper pipes...looks like aluminum pipe which doesn’t make sense for optimum heat transfer.
Thanks for the hint Vunce.
Please provide a link for your PWM temp sensing control.
Hi Eric,
The FD841’s come with two different copper base designs.
The ones with the rounded indents for the screwdriver to fit down past the aluminum fins has a large copper base that can fit two mosfets next to each other.
The coolers with square fin indents have a smaller diamond copper base perfect for a single mosfet.
I haven’t seen the FD841 with silver pipes?
12V PWM PC CPU Fan Temperature Control Speed Controller Module High-Temp Alarm | eBay
Cheers!
See pics:
