The adhesive should be on the outer circumference (outer vertical edge) of the gasket ring and on all of the metal frame (green) itself.
Not on the inner circumference (blue) nor on the top (pink) surface of the gasket.
The gasket push fits into the enclosure cut-out similar to the way that a sink plug push fits into the sink waste hole.
So I confused if to cut 72.5mm or 75mm..
I am talking about 75 mm for rear mounting as I have described in post #49.
So I just got the speakers and I wondered:The adhesive should be on the outer circumference (outer vertical edge) of the gasket ring and on all of the metal frame (green) itself.
Is it possible to use this glue instead of the silicone one? (for the speakers and the box itself)
I wouldn't use that glue for mounting the speaker as it is permanent in its action, unlike the silicone adhesive I recommended which would allow removal of the driver at a later date should it be required.
For woodwork, we use PVA wood glue. It bonds stronger that the wood itself and it is not messy in use as any surplus can be wiped off with a damp cloth.
Apart of the fact I won't be able to remove the driver - is there a reason not to use it in term of sound quality?
So if to understand the recommendation here:
for the box itself - to use silicone
for the driver - PVA wood glue
but in any case I could use the glue I linked for both box and driver? It is just not the best choice?
Thanks!
Thanks!
The driver requires the silicone adhesive for its sealant property, i.e., to prevent air leaking between driver and mounting hole.
Find a reasonably priced silicone sealant/adhesive to do both jobs.
It [the glue I linked] is just not the best choice?
After much consideration, silicone sealant/adhesive emerges as the best choice for your project.
I have this Knauf glass mineral wool - how much I should put inside the speaker box?
I applied silicone glue for making the box (all parts apart of the driver part) and now I would like to fill that box with the above material I shared a link too before soldering the driver and close it completelyWhat box? How is it ended?!
Fill all the volume paying attention that the damping material does not obstruct the rear cone/basket of the driver. Do not press the stuffing material, just fill the box.
If it's a vented box, apply the stuffing on the walls of the box and do not obstruct the path between vent and cone.
Speaker box made of 3.6mm plywood.Which box? Walls made of...? Why silicone? I've never used silicone! Hot glue, maybe
Silicon was suggested here
Can it touch the rear part of the speaker?(the magnet part)all the volume paying attention that the damping material does not obstruct the rear cone/basket of the driver.
- Full Range
- building boxes for speakers
