Thanks phofman,Clearly that particular kernel build does not include the snd-aloop module. https://github.com/radxa/debos-radxa/issues/44 -> install the headers and non-dbg image debs https://github.com/gerulrich/rock5b/releases/tag/0.0.1
The packages seems to install without errors. I did a reboot, but still the same message. Do I need to change any config files?
First check you actually booted into the kernel provided by that package - commands:
check what kernels you have:
ls /lib/modules
check what kernel is running:
uname -a
check what snd-asound modules for which kernel you have available:
find /lib/modules -name 'snd-asound.*'
ls /lib/modules
uname -a
paal@paal-desktop:~$ ls /lib/modules
5.10.110-99-rockchip-g 5.15.0-86-generic 6.2.0-1016-gcp
5.10.160-rockchip 5.15.0-88-generic
paal@paal-desktop:~$ uname -a
Linux paal-desktop 5.10.160-rockchip #15 SMP Sun Oct 8 15:01:49 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
I seem to be running 5.10.160. I guess it should have been 5.10.110-99-rockchip-g. You said find snd-asound, but nothing there. I assume you ment snd-aloop? See below:
paal@paal-desktop:~$ find /lib/modules -name 'snd-aloop.*'
/lib/modules/6.2.0-1016-gcp/kernel/sound/drivers/snd-aloop.ko
/lib/modules/5.10.110-99-rockchip-g/kernel/sound/drivers/snd-aloop.ko
Very good. As you see, the newly installed 5.10.110-99-rockchip-g kernel does contain the snd-aloop module, unlike the original kernel 5.10.160-rockchip. Now you need to make your board boot into that new kernel. Check your extlinux.conf as in https://wiki.radxa.com/Rock5/guide/build-kernel-on-5b#Install_kernel_packages and set the new kernel as default. Be careful to keep filenames and paths correct in that file, otherwise you may not boot again.
boot is mounted, but could it be that ubuntu has another way of changing kernel?
paal@paal-desktop:~$ ls /boot
config-5.10.110-99-rockchip-g System.map-5.10.110-99-rockchip-g
config-5.10.160-rockchip System.map-5.10.160-rockchip
config-6.2.0-1016-gcp System.map-6.2.0-1016-gcp
firmware vmlinuz
initrd.img vmlinuz-5.10.110-99-rockchip-g
initrd.img-5.10.110-99-rockchip-g vmlinuz-5.10.160-rockchip
initrd.img-5.10.160-rockchip
firmware vmlinuz
I do not know where you got your image, what is the boot method. Radxa uses u-boot with extlinux, there are other options for u-boot https://linux-sunxi.org/U-Boot#Boot .
I got ubuntu via https://wiki.radxa.com/Rock5/downloads
here: https://github.com/Joshua-Riek/ubuntu-rockchip
I am booting from NVME
This gives some hints https://github.com/Joshua-Riek/ubuntu-rockchip/wiki/Kernel-Command-Line
/boot/firmware/ubuntuEnv.txt
Also if you run that ls with -l parameter (to see what those names actually mean), it's likely vmlinuz and initrd.img are just symlinks to the original kernel initrd.img-5.10.160-rockchip ...
Just changing the symlinks to point at the files corresponding to the new kernel (image and initrd) may do. But you would need to change BOTH vmlinuz and initrd.img otherwise you will ruin your installation and would either have to reinstall the image or use serial console at boot (quite a complex procedure).
The new idea works! I made a separate sse2-version of the biquad calculations using intrinsics, and this compiles into a trouble free binary. I'll make a new release as soon as I can.But I had an idea for a different workaround.
I had a small hope that this hand-optimized version would also run a little faster, but that is not the case. I get exactly the same speed. The compiler is hard to beat!
I do not understand much of the content of ubuntuEnv:Also if you run that ls with -l parameter (to see what those names actually mean), it's likely vmlinuz and initrd.img are just symlinks to the original kernel initrd.img-5.10.160-rockchip ...
nano /boot/firmware/ubuntuEnv.txt
bootargs=root=UUID=d312d528-2e2f-4044-a702-659ba4cf55d5 rootfstype=ext4 rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cg>
fdtfile=rk3588-rock-5b.dtb
overlay_prefix=rock-5b
overlays=
Here is the ls -l content of boot dir. looks like symlinks. How do I modify them?
PS: I have reinstalled the image a number of times, so I am not afraid of that risk
paal@paal-desktop:~$ ls -l /boot
total 98324
-rw-r--r-- 1 root root 213159 mai 29 15:48 config-5.10.110-99-rockchip-g
-rw-r--r-- 1 root root 223382 sep. 30 18:14 config-5.10.160-rockchip
-rw-r--r-- 1 root root 321487 sep. 29 05:17 config-6.2.0-1016-gcp
drwxr-xr-x 3 root root 16384 jan. 1 1970 firmware
lrwxrwxrwx 1 root root 28 okt. 8 19:06 initrd.img -> initrd.img-5.10.160-rockchip
-rw-r--r-- 1 root root 14391415 okt. 14 09:32 initrd.img-5.10.110-99-rockchip-g
-rw-r--r-- 1 root root 14925175 okt. 14 10:24 initrd.img-5.10.160-rockchip
-rw-r--r-- 1 root root 7222742 mai 29 15:48 System.map-5.10.110-99-rockchip-g
-rw-r--r-- 1 root root 8398813 sep. 30 18:14 System.map-5.10.160-rockchip
-rw------- 1 root root 6352135 sep. 29 05:17 System.map-6.2.0-1016-gcp
lrwxrwxrwx 1 root root 25 okt. 8 19:06 vmlinuz -> vmlinuz-5.10.160-rockchip
-rw-r--r-- 1 root root 10395400 mai 29 15:48 vmlinuz-5.10.110-99-rockchip-g
-rw-r--r-- 1 root root 38203904 sep. 30 18:14 vmlinuz-5.10.160-rockchip
Google is your friend, e.g. https://www.freecodecamp.org/news/s...nux-how-to-create-and-remove-a-symbolic-link/Here is the ls -l content of boot dir. looks like symlinks. How do I modify them?
Unless there is some other config in the firmware directory (ls -l firmware), it looks like the path to the image and initrd are hard-coded in the boot manager and the way is to change the symlinks.
Thanks for gudiance. I changed the symlinks, but it seems to be more complicated. The symlinks is now linked to the xxx-99 kernel, but it still boots on the old kernel
paal@paal-desktop:/boot$ ls -l
total 98324
lrwxrwxrwx 1 root root 33 okt. 15 15:47 initrd.img -> initrd.img-5.10.110-99-rockchip-g
lrwxrwxrwx 1 root root 30 okt. 15 15:15 vmlinuz -> vmlinuz-5.10.110-99-rockchip-g
The old krenel still is in the firmware dir...
paal@paal-desktop:/boot$ cd /boot/firmware
paal@paal-desktop:/boot/firmware$ ls -l
total 51952
-rwxr-xr-x 1 root root 1883 sep. 14 23:14 boot.cmd
-rwxr-xr-x 1 root root 1955 sep. 14 23:14 boot.scr
drwxr-xr-x 3 root root 40960 okt. 14 10:24 dtbs
-rwxr-xr-x 1 root root 14925175 okt. 14 10:24 initrd.img
-rwxr-xr-x 1 root root 331 sep. 14 23:14 ubuntuEnv.txt
-rwxr-xr-x 1 root root 38203904 okt. 14 10:24 vmlinuz
total 98324
total 51952
I hate to be a Debbie downer but problems like this are why I stopped using ARM boards altogether. The Raspberry Pi platform is pretty good, but when I tried some products from Orange Pi and Tinker I encountered issues with the "custom kernel" that totally wasted time or prevented me from reaching my goal(s) with the boards. Now I stick with Intel based mini PCs. These can run a standard kernel and can be updated without breaking anything and are typically faster than ARM based SBCs. Since making that change I have had zero problems.
What is in those files boot.cmd, boot.scr?The old krenel still is in the firmware dir...
total 51952
Well then it looks like the boot manager takes the kernel files from the firmware directory. Just try overwriting initrd.img and vmlinuz with the new corresponding files from the /boot , make sure to keep the firmware/names correct, otherwise it may not boot.
boot.cmd
# This is a boot script for U-Boot
# Recompile with:
# mkimage -A arm64 -O linux -T script -C none -n "Boot Script" -d boot.cmd boot.scr
setenv load_addr "0x9000000"
setenv overlay_error "false"
echo "Boot script loaded from ${devtype} ${devnum}"
if test -e ${devtype} ${devnum}:${distro_bootpart} /ubuntuEnv.txt; then
load ${devtype} ${devnum}:${distro_bootpart} ${load_addr} /ubuntuEnv.txt
env import -t ${load_addr} ${filesize}
fi
load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} /dtbs/${fdtfile}
fdt addr ${fdt_addr_r} && fdt resize 0x10000
for overlay_file in ${overlays}; do
if load ${devtype} ${devnum}:${distro_bootpart} ${fdtoverlay_addr_r} /dtbs/overlays/${overlay_prefix}-${overlay_file}.dtbo; then
echo "Applying device tree overlay: /dtbs/overlays/${overlay_prefix}-${overlay_file}.dtbo"
fdt apply ${fdtoverlay_addr_r} || setenv overlay_error "true"
elif load ${devtype} ${devnum}:${distro_bootpart} ${fdtoverlay_addr_r} /dtbs/overlays/${overlay_file}.dtbo; then
echo "Applying device tree overlay: /dtbs/overlays/${overlay_file}.dtbo"
elif load ${devtype} ${devnum}:${distro_bootpart} ${fdtoverlay_addr_r} /dtbs/overlays/rk3588-${overlay_file}.dtbo; then
echo "Applying device tree overlay: /dtbs/overlays/rk3588-${overlay_file}.dtbo"
fi
done
if test "${overlay_error}" = "true"; then
echo "Error applying device tree overlays, restoring original device tree"
fi
load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} /vmlinuz
load ${devtype} ${devnum}:${distro_bootpart} ${ramdisk_addr_r} /initrd.img
booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r}
boot.scr
'^E^YVM^A^[Ze^Cw�^@^@^Gc^@^@^@^@^@^@^@^@^Q�:K^E^V^F^@Boot Script^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^G[^@^@^@^@# This is a >
# Recompile with:
fi
fi
done
fi
# Recompile with:
fi
fi
done
fi
boot.scr
# Recompile with:
fi
fi
done
fi
@CharlieLaub : I absolutely agree, I always prefer x86 unless Arm-only IO features are required (I2S, USB gadget, other interfaces).
The truth is making an ARM board run properly is always a major work. Done by RPi devs for RPi, other board vendor (in better cases) for a single kernel/distribution. Anything outside of that takes major effort for the user where some non-trivial linux skills are required, patching/compiling/deploying kernel, modifying device-tree, etc. etc. It's not for a user, but more like for a developer.
@paalj: Running a third-party distribution on Rock5 is not a trivial task and really does require some linux skills. I will have to go that path for my project, but am aware that it will be a fight. But there are not many other options as I need lots of CPU power with 768kHz multichannel in/out I2S + working usb gadget. RK3588 is one of very few SoCs practically available to try. What is your reason for using this still vastly unexplored path? I am afraid even if you get this kernel work and your snd-aloop module load, what next steps do you plan? Do you have the skills e.g. to make the dwc3 usb gadget or I2S output work? If not, why do you struggle with this unsupported board?
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
