Re: Re: Re: Re: Email Functionality
Hi Tony,
I will try again. The file is only 38 kB.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
apassgear said:
Never heard of this happening to me before , and as far as I know I have no restrictions.
How big are the files?
apasgear@avantel.net
Hi Tony,
Re: Re: Re: Re: Re: Email Functionality
Finally did it, thanks a lot Elso.
Woow, V.7!!!!
![bigeyes :bigeyes: :bigeyes:](https://files.diyaudio.com/forums/images/smilies/bigeyes.gif)
Elso Kwak said:
Hi Tony,
I will try again. The file is only 38 kB.![]()
Woow, V.7!!!!
Homepage
Per,
Don't tell me what to do.
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
peranders said:Elso, why don't put up a homepage since you don't charge anything for the schematic? I have asked this before but it makes no sense to me this manual work.
Per,
Elso Kwak said:Dear fellow forum members,
After mailing so many schematics I have enough of it. I have better things to do with my precious time. I am getting too old for this....![]()
Good luck!
I'll guess you have rejected the homepage idea for some reason but this was a solution of getting more spare time, since you complain about it.
No need to get grumpy.
Download
Hi Chijen,
You can download it here (post #45, page 3 of this thread):
http://www.diyaudio.com/forums/showthread.php?postid=199928#post199928
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
chijen said:
Hi Chijen,
jUST curious how the ver 7 clock works? How does it compare to the tent clocks?
My experience with two built kwak 7 clocks and one XO tent clock:
I had in my NAD 541i a (bad) implementation from a single supply Kwak clock 7. Today, I just removed the ferrite beads supplying the clock part and inserted a 8pin socket, the ferrite bead delivered with a tent XO, a 0.1uF cap and the XO itself.
The result is really good, the quality of this player is now better than my tweaked NAD510, including a good working kwak 7 single supply. Before was no remarkable difference! More details but some kind of softer than the other player. Lovely!
My conclusion is: Maybe, the kwak clock is working fine, when perfectly implemented AND measured. This means having adequate RF- and electronic knowledge and measuring equipment.
Otherwise, the result could be unpredictable
When using the XO canned module, just add a fine psu, a correct and short connection to the player and you can be sure the result is worth the money and time!
Franz
IMHO, Kwak Clock 7 must be supplied from a symmetrical ps, as this allows for adjusting symmetry of the output square waveform.
You see, this is exactly my problem, not having the adequate measuring equipment: for example my scope (old Heathkit OS2) is O.K. for audio purposes, not for frequencies above 100kHz.
So, I cannot test, if my clock is working well or not!
Elso recommended me to use a single supply in the NAD541i, as there is no symmetrical voltage available.
With the XO tent clock, I dont have such questions and problems to solve.
Easy!
Franz
kenev said:IMHO, Kwak Clock 7 must be supplied from a symmetrical ps, as this allows for adjusting symmetry of the output square waveform. I' m not a digital expert, but, to my understanding, this must be beneficial for the clock performance.
Just my 2p.
could you explain why the symmetry is that important ?
- Digital Line Level
- Can someone send to me the Elso's latest clock schematics (version6)? :)
