Yes,probably.Maybe I make direct class D from SMPS output,with sync. rectifierBut you'll see, even if simple - still complicated.
Mag amp isn't bad as doctormord say.I tried it without feedback,and sound is ok for me.
You can use any PSU,boost can't increase voltage on electrolytes because speaker reactive energy is small to do this.As I say,first try on 150khz.I make mag amp in halfbridge and pushpull,and it don't require PSU cap's.SMPS directly power it.But this is for sub and mid's because sw. freq. is cca. 35khz
Very good.
So I go with standard pcb and standard schematic (the corrected ones, of course).
Linear 80V single ended.
To complete my design I have to choose output mosfets.
Any suggestion on the best choice for 100W/4ohm/80V single supply?
Saluti.
Yes,can be implemented,but I don't tried on this,but tried on similar amp.Hi Acca,can a postfilter feedback be implemented on this amp?Did you try ?How much power can i get with +/-100V from this amp on 4 ohm
+/-100V give 1kW on 4R
You should use totem pole at IR outputs for this power.
Thanks for previous suggestions.
I don't understand which is the right formula to use to obtain the correct rms Po.
Fom here:
Pse(PEAK) = Io^2*RL = (Vo/2Rt)^2*RL = ¼(Vo/Rt)^2*RL = 2 • Pse(RMS)
So: Pse(rms)=80V*(80V/4)/2=800Wrms (??)
EDIT:
with +-100V: (200*200/4)/2=5000Wrms (??)
I think we have to consider the efficency too:
With an eta=90% we have:
800W*0.9= 720Wrms
5000W*0.9= 4500Wrms
So what?
EDIT:
So what?
It's formula for half power of resistor placed between +100V and -100V rail.
It's a two 5kW resistor in series,2 ohm each and with 200V across it.
So it is useless.
So it's not true.
P=U^2/R
R=4ohm
U=Udc/1,4
U=100/1,4=70VAC
P=70*70/4=1225W at input
1225*0,9=1100W at output.Rms.
With single supply calculate U=Udc/2,8
So it is useless.
Yes, ok.
I forgot to reduce current peak to rms, and forgot that when mos up is on then lower one is off, so I have to consider half voltage.
So: #/(2*1.414) = Vdc/2.8
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
I deepened a bit theory of class D amply,
and seems that an advantage of clocked frequency amplifiers vs auto oscillating is that the first are easily syncronizable.
Of course, I would like to build a double stereo amplifier, in order to mantain up way separate from down way (there are differences on sensibility and I need to regolate volume independently).
I guess I have to syncronize the PWM ICs.
Is this a feature supported by SG3525?
EDIT:
answer is yes:
Synchronizing SG3525 - diyaudio
EDIT2:
/OT ON:
answer is yes, but I don't know how to
OT OFF/
EDIT:
answer is yes:
EDIT2:
/OT ON:
OT OFF/
Yes, ok.
You got the point
See datasheet!![]()
Yes, I do
You don't have to sync IC's,but it will be good.
Isn't better to sync?
Anyway, my troubles are about ICs being slaves by adopting external osc, or being one master and one slave.
But...ehy, I still have to deeping datasheet
![upsidedown :usd: :usd:](https://files.diyaudio.com/forums/images/smilies/usd.gif)
- Class D
- DIY Good Class D amplifier
