SIP 3 ...
A DAC will do Hi/ AB warmup , then default to the passive setting.
Remote control variable AB and extended "first watt" Hi-AB.
Officially , the new amp will be open ended (for this).
The old 80 Genesis stealth amp had a (infrared) remote to toggle it's class A bias.
That's all it did , could not create "profiles".
With just a BJT , the DAC would do from default (40mA) to 1/2A per
device. SIP 3 is a winner.
OS
OS
so instead of running after ppm distortions, how about designing for users who would love to see their amps destroyed instead? i would love to see them frustrated for a change....
It sounds like you want a pro-sound amp instead of hifi. Consumer grade and roadie proof are two separate animals. Usually people who take the time to build their own amp will use some common sense when operating it. If not they can have the fun of figuring out how to repair an exploded amp.
It's easy to add a protection system like our Amp Control system. With it connected you can abuse the amplifier as much as you want in normal operation, it will simply turn off if the amp is going to get hurt. I wouldn't recommend shorting the output leads in operation but normally it will save the amp in that situation as well. The speed of digital control and solid state relays is hard to beat with old analog / mechanical protections and doesn't degrade the sound like I/V limiting.
I completely agree
I can't enjoy any amplifier without protection.
Amplifier's repair is an easy job but speakers are very expensive animals!
A good protection like 21" century protection by Jeff & Valery is a very good option.
Do not trust relays in this position.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
P.S i can accept amplifier's burning but not speakers destroy![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Prosound ...
Pro sound design also has some plus's.
My Behringer 150w amp plates use 250v ltp's and mirrors. They bias the OPS almost at class B.
They base both the Badger-like CCS's on two 1A diodes and a big resistor.
Not much can go wrong.
Pro sound simplicity is a factor I add to any design .... will it last 20 years ?
They did not have any protection on the speakers that went with the
Behringers. The one other buyer on ebay said 21 years , he was happy he found
the replacement and the speakers sang !! So the old amp did not burn the
speakers.
I bought 2 for 30$ , my 2 subs sing !!
PS - but I WILL add a protection to my big sub in the future. It cost over $200.
OS
speakers.
OS
Been reading the honey badger build guide. on power supply recomandation. I dident understand the last part.
he amplifier was tested with a power supply of +/-63V (from a 45-0-45transformer).
The transformer used was an AnTek AN-8445, 0-45V x2 @800VA.
The PSU board used were a pair of diyAudio P-PSU-1V20 boards, one for eachchannel.
Recommended capacitance is a total of 40,000uf per rail. If you are using thediyAudio PSU board, that would be 4 X 10,000uf caps per rail for a total of 8 caps.
If the recommended AnTek AN-8445 transformer is used, a minimum of 75Vworking voltage is recommended
where did the number 75 come from?
Hi guys. I,ve decided that mi next protect will be this one. Will you tell me what do i need to buy? obviously the two boards (stereo set) but then i got lost in psu's, soft starts and such matters. I want to make the order and i would like to buy all the recommendable boards in one order.
Its not my first project but you know i just follow the instructions.![yes :yes: :yes:](https://files.diyaudio.com/forums/images/smilies/yes.gif)
What I've put together for items needed
So I've decided to put a list together of cost... chassis are pricey![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So here's what to buy from DIY...
1. SOFT START & SPEAKER TURN-ON DELAY / DC PROTECTOR COMBO $25
2. BACK PANEL PARTS KIT PLUS PCB / TRANSISTOR / DIODE MOUNTING PARTS KIT FOR THE DELUXE CHASSIS $79
3. ALUMINUM DISSIPANTE SUBSTITUTION: "DELUXE" REAR PANEL
(ONLY COMPATIBLE WITH DISSIPANTE CHASSIS WITH ALUMINUM TOP AND BOTTOM COVERS) $11
4. DISSIPANTE 4U $299
5. DISSIPANTE SUBSTITUTION: UMS HEATSINKS $59
6. UNIVERSAL POWER SUPPLY board $25
7. THE DIYAB "HONEY BADGER" CLASS AB POWER AMP - 150W/CHANNEL $39
TOTAL from DIY AUDIO Store $537
I spent some time today to source semi's and special parts needed for the build.
Avel Lindberg Y236853 625VA 40V+40V Toroidal Transformer $100.00
You will have to decide how many of each item you need from the BOM's.
I usually get 10 of each...
THIS IS NOT A COMPLETE LIST!!! Just the stuff I do not have on hand...I hope...
Mouser...
KSC1845FTA onsemi / Fairchild | Mouser
KSA992FTA onsemi / Fairchild | Mouser
1N5408G onsemi | Mouser
BAV21-TR Vishay Semiconductors | Mouser
https://www.mouser.com/ProductDetail/511-MJE340
https://www.mouser.com/ProductDetail/511-MJE350
https://www.mouser.com/ProductDetail/667-ERX-3SJR47V
https://www.mouser.com/ProductDetail/667-ERG-3SJ223A
https://www.mouser.com/ProductDetail/756-MFR4-27KFI
https://www.mouser.com/ProductDetail/756-MFR4-470RFI
https://www.mouser.com/ProductDetail/71-CMF5510K000BEEA
https://www.mouser.com/ProductDetail/660-MF1-2DC47R0F
https://www.mouser.com/ProductDetail/660-MF1-2LCT528R333J
https://www.mouser.com/ProductDetail/660-MF1-2CC1503F
https://www.mouser.com/ProductDetail/594-HVR3700002703FR5
https://www.mouser.com/ProductDetail/512-KSC945YTA
https://www.mouser.com/ProductDetail/769-JS1F-5V-F
https://www.mouser.com/ProductDetail/594-S103K75Y5PN83K0R
https://www.mouser.com/ProductDetail/80-R46KN4100DQN1K
https://www.mouser.com/ProductDetail/660-MOS3CT631R221J
https://www.mouser.com/ProductDetail/594-5093NW1M000F
https://www.mouser.com/ProductDetail/280-CR5-180-RC
https://www.mouser.com/ProductDetail/660-MF1-2LCT528R222J
https://www.mouser.com/ProductDetail/769-JS1-F-24V-F-6K
https://www.mouser.com/ProductDetail/534-8197
My Total is about $100.00
Digikey
https://www.digikey.com/product-detail/en/513201B02500G/HS347-ND/1216354?itemSeq=377107587
https://www.digikey.com/product-detail/en/FEP30DP-E3/45/FEP30DP-E3/45GI-ND/604818?itemSeq=377107661
https://www.digikey.com/product-detail/en/0398900303/WM15826-ND/809413?itemSeq=377108793
https://www.digikey.com/product-detail/en/ERX-3SJR47/P0.47W-3BK-ND/36497?itemSeq=377108989
https://www.digikey.com/product-detail/en/ERX-3SJ1R0/P1.0W-3BK-ND/36521?itemSeq=377109129
https://www.digikey.com/product-detail/en/LLS1J103MELB/493-7279-ND/2548884?itemSeq=377109257
Newark Electronics
https://www.newark.com/on-semiconductor/mje15033g/bipolar-transistor-pnp-250v-to/dp/45J1498
https://www.newark.com/on-semiconductor/mje15032g/bipolar-transistor-npn-250v-to/dp/45J1497
My Total is about $25
Wow it adds up fast... This is NOT all as I have my normal supply of resistors, caps and pcb parts.
So If I total all this up... $785 US
Glad I did this...
Would love to build one, but...
Scott
Mouser...
Digikey
Newark Electronics
Glad I did this...
Scott
Agree...But Gsusay wanted to know what to buy.![]()
and I thank you a lot the work.
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
One of the secrets to enjoying this hobby is to never add up the costs to build an amp.
And that analyst lacks the biggest cost. Time, much more expensive that all this material stuff. At least for me.
Bias adjust and oscillation
Hello
Yes Anatech is right, this is the fact, something is oscillating and explains the jump of iddle current.
I had a problem like that on one of my 2 amps.
I solve the problem with a small capacitor across base and collector of Q 12.
Now I have another question.
Did you experiment thermal drift on your amp ?
One of the 2 amps I build seems to have some thermal problem.
Unfortunately the amp is not at home and I have no possibility for the moment to analyze the phenomena.
In both of my amps I have included a speaker delay protect with dc control on the output in order to avoid any bump and dc leakage through speakers.
Last time my brother who lives in the "hot" south of France saw the amp stopping to work, but all the control Led where lighted.
If the amp doesn't work with correct power supply that means that the speaker security is active.
It happened after 6 hours of continuous working and he said that the amp had become hot.
Heat is not a problem because I used large heatsink and I had included thermal protection. The thermal test devices are directly screwed on the 2 heatsink.
During summer when it was really hot the thermal security had operated once but in this case the amp stop completely and all led vanished.
This is not the case this time.
Any one had experimented thermal problem on the badger ?
The second amp I use everyday has no probleme of this kind and the DC at the output remain inexistent even after a full day of operation.
Ambient temperature in Paris area is lower than south of France !
If you have experimented such trouble please let me know.
I think the problem occurs in the input stage.
I take great care of the input stage and all transistors have been carfully paired. I bought 40 transistors off all type and paired them patiently.
Any idea will be welcome.
Thank you
Best regards
Stick a 'scope on the output when you are adjusting the bias. It could be oscillating.
-Chris
Hello
Thank you
Best regards
Never had any heat issues with my Badgers for all these years. They are running cool. I don't see how hot weather could be an issue with an AB amp in domestic applications.
I''d check for bias drift in the output stage, which might also explain why the DC protection kicks in.
- diyAB Amp - The "Honey Badger"
