diyinhk
could you please specify ES9018K2M current output parameters ?
Your I/V output stage with only one opamp looks good, but later i would like to try some discrete stage.
Michal
the iv feedback resistor used in the official datasheet is 2.32k.
but the data in the analog output section on the datasheet is the same as the original es9018.
I can see the DAC on pages without problem
ES9018K2M XMOS DSD DXD 384kHz USB DAC with Bit-perfect volume control and SPDIF input - DIYINHK
Cables are sold separately
XH Cable 25cm AWG22 - DIYINHK
I just rec'd this, I'm testing a digital power supply for it, when I get it finished, I'll report
Hi timlub,
i'm waiting for your experiences. What "digital" power supply you have?
There are two options:
1) DAC only for 70 usd
2) DAC + XMOS with LED for 140usd
or you can take just the DAC for 70usd + XMOS without LED panel
XMOS DSD DXD 384kHz high-quality USB to I2S/DSD PCB - DIYINHK
and save 10usd (130usd final price)
Hi Misak, found this on ebay... checking it for voltage consistency under load, noise etc.... it was really cheap, but seems to fit the bill. It might need some additional filtering.
New Strong Power Universal DVD Power Board 5V 3 3V 12V 12V 21V | eBay
Tim
Tim
Hi Tim,
this is switching power supply - very bad idea for DAC ...
I think even this cheat LM317/337 power supply will be better
Assembled LM317 337 dual power adjustable power supply board #Li 12-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com
LM317 Step Down DC 5V 35V to 1.25V 30V DIY Kit AC/DC Power Supply Module Free Shipping-in Electronics Stocks from Electronic Components & Supplies on Aliexpress.com
or you can use this two discrete power supply
The New Power 20 High End Pre Linear Adjustable Power Supply Board Kit SN | eBay
Kubota Low Noise Regulator Full Blown Version Kit | eBay
but the price for this two is almost same as for much better 4uV regulators from DIYINHK
4.17uV Ultralow noise DAC power supply regulator +-12/15V 1A - DIYINHK
4.17uV Ultralow noise DAC power supply regulator 3.3V/5V 1Ax2 - DIYINHK
and this transformer ...
High Quality Audio 30W AC 220V R Core Transformer for Preamp 15V 15V 9V 9V | eBay
Hi Misak,
You may indeed be correct, I don't claim to be a tech.... Just testing, it shouldn't damage anything to try it. I can always drop in an analog supply... right now the little supply that I posted seems quiet, and is plus or minus just a couple of % from its posted voltage under load...Ripple current was good also. Haven't actually put the supply in the box with the boards yet, but I'll most likely at least give it a listen. I've seen digital supplies in with DVD and CD players many times. From my feeble brain logic, it should at least work.... its a busy time for me at the moment. It will most likely be a couple of weeks before I listen to it. I'll let you know.
Hi Tim,
no problem, my previous post was informative only.
Feel free to use your way ;-)
I will be glad if you post your experiences even with switching power supply.
I have now ODAC and i'm affraid that i must buy ES9018K2M with low noise power supply for hear some improve in sound. But the cost of ODAC was only 99USD and ES9018K2M+dual 12V+5V power supply+transformer=255USD :-(
The little supply that I posted switches right at 200k, it only varies by a few hz at full load, it is filtered now at every stage, it is quiet and fairly well regulated. I expect it to work fine and sound decent. If need be, a simple cap & coil will add some nice filtering. Yes, a really good analog supply would be better, but I do expect this to be quite good and about one tenth of the cost. If I'm way off, I'll let you know. Tim
Hi, I am quite new to the DIY DAC thing, but after getting a Raspberry Pi I am very interested in them. The problem is that the more I read the more confusing it gets.
But I ended up at here...with some questions.
Can I loose the USB part when using a raspberry ?
If so do I need a separate clock?
And which kind of extra power supply would I need?
Xerxes
Xerxes
Hi Xerxes75,
I'm not sure that I'll solve any confusion. What are you trying to accomplish? I will answer your questions based upon that you are looking at using Raspberry PI as a computer audio product... If that is the case the Raspberry is not the best choice... I believe most people use Linux on Raspberry. What operating system are you using? Linux? That changes the need for drivers. Most computer audio programs require 4gb ram to do a decent job i.e. Foobar 2000 or JRiver.
As far as using USB... You need to feed your files some way to your DAC. Whether that be by USB, SPDIF or Toslink, so no, you don't need to necessarily use USB, but it is becoming the most accepted format.
Do you need a separate clock? Again, I am assuming that you have been reading about Adaptive vs Asynchronous mode of getting your files to the DAC.... An Adaptive system lets your computers clock time your files before the DAC, An asynchronous system takes the files from your computer and re clocks them at the DAC.... Asynchronous is known to have better timing, lower jitter and overall better sound and which type of power supply do you need?
Assuming that you are going to use the DIYINHK DAC that this thread is about? The standard practice would be an analog supply, this DAC requires 3 feeds. 1 - 3.3v, 1 - 5v and 1 - 12v.... if you didn't want to use a power supply, batteries sound excellent. I am a bit off the normal path and will most likely hook up my switching supply this week end.
I'm not sure that I answered a single question as you intended. There are a bunch of people on this forum waaaay more knowledgeable than I am, read this, give good example of how you want clarification, I'm sure someone will chime in and help out. Tim
Hi Timlub,
Thanks for your reply. I want to use the Dac in combination with my Raspberry using Volumio or RuneAudio and I want to connect it direct via I2S using the P5 connector on the board. The reason I ended up here is that there are numerous examples using the Raspberry and the ES9023 DAC and adding a clock, I want to use less boards etc.
Off course I can just go and buy a Hifiberry or some sort, but I want to aim a bit higher (and less obvious).
Xerxes
Xerxes
- Vendor's Bazaar
- diyinhk Store
