That looks better, having the waveguide a db lower or filling in the saddle in the woofer response might help a little to avoid that slight rise and dip between 1 and 5K in the combined response.
Just remember that without phase data for the CD and waveguide any crossover simulated here won't work out the same in reality. In trying to show you an example before I used a 2nd order crossover without needing to flip the phase of one side. In real life it would have had a massive dip at the crossover point.
With the help of @fluid I started a full scale print. A first prototype to see what problems might occur.
- mounting screws are almost to high and are very close to the (inner part of the) Waveguide. Will switch to the outer two mounting holes as mentioned by fluid.
- Printer has developed some weird behavior. Going to try to solve it by increasing belt tension.
- round holes are not round. Might be caused by stl export. Investigation needed.
- Ran out of filament. Well, that was actually expected.
- Find a way to fill it.
Some drivers come with threaded studs which would mean only a washer and nut needs to be put on in the cutout.mounting screws are almost to high and are very close to the (inner part of the) Waveguide. Will switch to the outer two mounting holes as mentioned by fluid.
It looks like you used gyroid infill, if so that can be filled with resin as there are gaps through the infill to let the resin flow. Just be careful as many resins get hot when they cure which could warp the plastic.Find a way to fill it.
Is the horn stub three separate pieces?
The point of an OS waveguide is said to be smooth and limit the 2nd derivative (still don't understand what exactly...); smear the change in angle out evenly as opposed a diffraction slot.
The problem here is that there is a 1mm gap. And also because of the throat angle of the CD and this gap, the throat of the waveguide does not have the correct size. It feels a bit penny wise and pound foolish: have a very well defined waveguide and then accept a gap where the CD and waveguide come together.
Leave some tolerance on the CD mount bolt holes so that the throat can be aligned. My commercial waveguides have some allowing align/misalign.
Mabat did some tests with the exit angle mismatch and the effect wasn't much in simulation at least (in ath thread somewhere). Angle is customizable with ATH script anyway. I think the conclusion was that all that matters is the exit wavefront of the driver and while a waveguide could be made to help fix/match poor CD it is very hard to do as we don't have perfect models for the driver. Just use best/good driver, which you know you have if measurements match simulations closely (enough).
For the gap due to the foam, people mention to fill it with some putty, parhaps play'doh or something I don't know. Mark100 has posted he doesn't bother these days as it doesn't seem to matter with his MEH builds, square throat.
If you have time to experiment with these please post your results and thoughts as this is something common to all. Thanks! 🙂
Hey,In the past I've build two guitar tube amplifiers, moved on to a tube hifi stereo amplifier (6V6 PP 10-15W) and I've been contemplating building a loudspeaker for quite some time now. I started researching the Klonwall and made CAD drawings, went to 3-way, looked at Full-Range, was pointed towards a transmission line speaker by a colleague, started designing crossovers using VituixCad, discovered active crossovers: I've read so much I forgot most of it again...
At the moment I think I would like to build an efficient 2-way, (12" - )15" woofer with a compression driver, like e.g. ToneMaster (https://audio-creative.nl/projecten/audio-creative-tonemaster-ii/), Calpamos (http://www.humblehomemadehifi.com/download/Humble Homemade Hifi_Calpamos.pdf). As everything is a first I plan to do quite some research and designing on the computer. Therefore I plan to use e.g. a miniDSP 2x4 HD as an active crossover with a UMIK-1 to measure SPL. I have a (second) SS amp I can use for the time being. I've used REW for testing my tube amplifier and made myself a little box to measure speaker impedance curves with it. I feel the active crossover will allow me to let me experiment with e.g. different crossover frequencies (which I consider as part of the journey); after I've measure the drivers in the actual enclosure. Eventually I might build a passive crossover, we'll see what happens.
Now the questions:
Any great drivers? (100 to 200 euro per driver, you get bonus points for cheaper, yet good, drivers)
Any general advice?
Any (other) examples?
Books to read?
miniDSP alternatives?
As you might read between the lines I have a severe case of analysis paralysis and 'choice stress'.
Very interesting thread. I’ve been around the block building speakers for personal use. Perhaps an open baffle design may be of interest? If so google Dick Olsher.
He offers some diy designs that you may find interesting.
Btw,
The Calpamos is an intriguing design. I’m a big fan of humble homemade hifi. I especially like the capacitor evaluations.
I used plasticine putty to fill a cavity between an Eminence screw-on adapter and a JBL waveguide. It works perfectly fine. The effect of a small mismatch of exit angles and throat is not a big deal.
https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-6475246
https://www.diyaudio.com/community/...-design-the-easy-way-ath4.338806/post-6728508
I'm slowly moving forward. Recently I've been trouble shooting the 3d printer (belts too loose, excentric bolts to tight, underextrusion,...). At the moment I'm doing autopsy on some blisters on top. Curiously, a more experienced 3d printing collegue on a different brand printer has them also...If you have time to experiment with these please post your results and thoughts as this is something common to all.
In the mean time I'm reading up on measuring and DI.
The foam is 2mm thick and I think it won't compress more than 0.5-1.0mm overall, even though by applying localized pressure you can easily squash it.
I can compensate the throat radius for that. Angle stays the same. I'll oversize the mounting holes a bit, but the printer is quite good at printing the right dimensions. The foam is positioned much less precise.
Edit: One should not put PLA in the sun. Even in the Dutch spring they deform easily in slight pressure.
It looks like you are too close to the bed if the blisters are from the bottom. I would not worry too much about the transition. A perfect seal is much more important.
Edit: I re-read your post. If the blisters are from the top layer, I would increase the number of solid top layers, the infill looks also a bit too sparse.
^^ yeah looks like the foam is not well centered. Perhaps it doesn't matter because the company is probably well capable of precise construction but still didn't apply it here. You could cut foam donut from around the throat and reposition it better. Not sure how tight the glue is, perhaps try small cut on the outer edge first as it is not that critical there if it gets ripped/ruined.
Orange phase plug tells it is a FaitalPro driver? I think my hf10ak has the foam bit of as well, shame on them.
The same driver can play lower on a deep horn than a shallow one. My own tests with a 1" show about 150Hz difference when comparing a short horn toThe CD's I've seen have the resonance much higher, which was said to be a problem here. Or is that resonance peak dependent on the horn?
a longer one (similar to the Celestion 90*40 you linked earlier).
i.e. the 20cm deep Celestion horn will support a slightly lower crossover than most PA horns.
Rabbit hole nr. 47632586
And what about a 2380 with an adapter?
The basic idea is fine, but not that particular horn, IMO. The 2380 has hard angles (a slot in the throat) to scatter the output, to allow a 2" driver to have wide horizontal coverage, to cover a large audience.
Since that is not your application, a horn that does not have those hard angles will be better. I note that is what you are going with in your 3D printing.
Why not revisit that idea by using a large horn (or a found object) for the mouth of your project - and then you only have to print the throat, and glue them together. The attached image is a speaker I was working on, which used an Ikea bowl as the horn. I've seen multiple other found objects that would work similarly.
I found that the afp file as generated by ath is very easy. And as I still don't like Fusion, I reverted to something I know better. I wrote a matlab/octave script to generate afp file based on the ROSSE function and some of @fluids ideas on how to make the waveguide. It's not as neat and handy as I would like it to be, but it's a start. Max print angle, minimum flange radius and minimum thickness can be entered. Flange radius is changed to match the maximum print angle.
You could change the shape to make a cutout for the bolts all the way round and then sweep the red shape over a partial circle as a path to fill it back in, instead of extruding cuts into the waveguide body.
A meaningful comment that I can endorse.The same driver can play lower on a deep horn than a shallow one. My own tests with a 1" show about 150Hz difference when comparing a short horn to
Picking up this project after it has been collecting dust for some time as I've been busy trying to keep the energy bills from exploding...
I switched back to mabat's approach and printed the throat. I tried to outsmart mabat by adding an alignment feature, but completely overlooked the print support needed and the consecutive less than optimal fit.
Some say I'm a perfectionist and my pile of test print parts, but no finished part might be considered evidence. This time I said to myself that I was going to finish it, perfect or not. We'll see 😳
- Efficient 2-way
