Blues said:
That would be a pair of Papajammies, Jacco.
I am just asking recommended parts.
Not alternative parts, resources or PCB……papajammies
Be nice or I’ll bring democracy to your home
![sarge :sarge: :sarge:](https://files.diyaudio.com/forums/images/smilies/sarge.gif)
![wave2 :wave2: :wave2:](https://files.diyaudio.com/forums/images/smilies/wave2.gif)
juma said:Guys, what do you think about this board ?
It's meant to be 44 mm x 44 mm in size, and the parts are named after Mr. Pass' schematic and only difference is that I added R71 and R81 (3 x 150R 2W resistors, instead of 2 x 100R 3W as Mr. Pass had drawn - I don't have 3W resistors).
Momentarily I'm in search for 2SJ74/2SJ108 JFETs (beware of Siliconix/Vishay J108 switching JFETs - in local shop they almost sold me those as Toshiba's - they even had the nerve to ask a 4$ per piece).
without any checking of functionality ( there I choose to believe
Parts....
mike_diy,
You may be met with resistance on this unless you formulate a BOM, something Ed LaFontaine suggested earlier. Basically, without doing the work, (or at least some of it), people are reluctant to help around here. It also shows that you want to help the collective by offering up a BOM that helps everyone if correct.
If you compile the BOM with supplier, brand, part (value, voltage, current, etc...), supplier part number, and quantity, people will have something to comment on. Without it, people will say whatever they want like, "Mmm, hard to believe all i want is a pair of pyjamas".
Nelson does say what resistors he uses in the Ax article, and sites manufacturers for the FET's as well. If you look around a bit in other threads you will see what others have used for other PassDIY/Fx projects. Lastly, Peter Daniel and other have posted their own personal opinions on different parts in different circuits and different locations. Someone once told me "There is no such thing as a free lunch and nothing more expensive than a free drink."
Chris
mike_diy,
Chris
Be nice or I’ll bring democracy to your home![]()
At last!!Democracy is found!!You had it all the time ,I bet.
As for parts the only question I had was the wattage on the jfet bias resistors. Someone said 3watts ;I said too big. Other than that question everything else was covered by NP. Looking through his many design article he has been casually specific that SUPER parts were not needed. I did all the parts from Mouser ,online, in an hour with delivery in three days. Opps..Had the jfets from Jackinnj...The Country Store.
Juma,
The only thing I would offer is with respect to the position of the outputs on such a compact board. Your layout makes the 2 of them a virtual point source of heat. It may benefit if they were rotated out onto opposite sides of the board. This would effectively give them more heatsink within which to dispense their heat. This does depend upon a particular heatsink you may have in mind. The article references TWO 8" X 6" sinks per channel. There is plenty of room.
Originally posted by Ed LaFontaine
Juma,
Yes, it does appear to be a possible optimization point, but I prefer this type of arrangement which offers a benefit of shorter traces in output section. However, I never experienced a problem in practice with "point source of heat" (I built Aleph and F4 this way) approach, so I'll stick to it (Aluminum is fast enough heat conductor, I suppose).
Thank's for input, Ed !
yeah ...... hotrod-ing is usual thing in Serbia .......
![rolllaugh :rofl: :rofl:](https://files.diyaudio.com/forums/images/smilies/rolllaugh.gif)
(I'm driving '84 hotrod-ed Stojadin ........ what's few hot mosfets comparing to that .....
![clown :clown: :clown:](https://files.diyaudio.com/forums/images/smilies/clown.gif)
kraljmatjaz said:Is there any chance for a PCB's group buy?
Bye,
Boris
Sorry, no, I don't have the means for that, but everyone is is free to do whatever he likes with it. I'll just make two pieces for me (home production)
(I'm driving '84 hotrod-ed Stojadin ........ what's few hot mosfets comparing to that .....)
Especially when rods glow in the dark
jacco vermeulen said:
![bawling :bawling: :bawling:](https://files.diyaudio.com/forums/images/smilies/bawling.gif)
Yes, that's Stojadin !
Here is a headphone amplifier looking very much like a bipolar F5...
http://users.otenet.gr/~ATHSAM/headphone_2.htm
Skorpio said:Here is a headphone amplifier looking very much like a bipolar F5...
Except it's full of capacitors
I saw this on the simulation, and had to see in real life. The response continues to rise the output was 2.83V into 8 ohms. I let the amp cook at 1.3 Amps, 24V for an hour and it stabilizes quite nicely. The heat sink is cooled with forced air at around 100LFM.
Simulation:
Results at 1W into 8 ohms:
(the AP only goes to 200kHz)
Simulation:
GRollins said:Easily enough fixed if it bothers you. Just put caps in the feedback loops...or the drive line...or the input resistor network...or...
I wouldn't lose any sleep over it.
Grey
What bothers me is that the results are dissimilar from those illustrated in Chart 12 of the AX article.
The distortion I see is mostly 2nd order as well.
Have you tried trimming R1 or R2?
By trimming the gain between the top and bottom halves of the circuit It is possible to significantly reduce the second harmonic.
Cheers
Tim
I built one channel with an IRfp240 and the Fairchild P channel
part named in the article, so I'm going to assume that the primary
issue is the IRFP9240.
Somehow I remembered commenting in the article about the
IR version of the IRF9240 with regard to the performance, but going
back, it appears that I probably remember it from this thread.
The IRFP9240 from IR suffers from the high frequency shelving of
the transconductance figure which makes it difficult to use in
Common Source applications. You need to replace it with a 9240
made by Harris or Fairchild (or anybody else). I used the Fairchild
FQA12P20 with good results, the ones you saw in the curve.
I recommend that you get a pair of FQA12P20's from Mouser as
a start.
The IRFP9240 from IR accounts for the second harmonic, which you
will probably note favors the + half of the output with increased
amplitude (2nd harmonic), and you should also see that this effect
occurs from the mid audio band up and is not seen at low frequencies.
This stems from the decreased gain of the P channel device.
The response peak on the top is likely also an artifact, and if it's
still there after replacing the P devices, there's a number of ways
to tweak it out. Alternately if you don't mind the distortion figure
of the IR P channel parts, we can tweak those for flatter response.
Last question, what is your supply voltage?
a start.
- F5 power amplifier
