needs more midranges for symmetry
Tell that to my 8-foot ceilings.
se
Already been done by LIPA in NY (Long Island Power Authority), at least over a short run
World?s first transmission voltage superconductor cable energised successfully in LIPA?s power grid - Nexans
Hmmm. I wonder if that explains the plaque, the potted wire samples, and the newspaper article hanging in the lobby?
John
I need about 10 meters of that for my speakers. Who has samples?
If the stuff weren't about a hunnert bucks a meter....sheesh.
Unfortunately, superconducting cables still obey that darn maxwell guy...L and C will still do the same thing..
J
Sheesh indeed. That's entry-level pricing for audiophile cables today.
se
J
But, but...but R, i mean its R =0, not almost. We need that in speaker cables. I kid of course.
On anothing kidding note, i can see some of the cold from the liquid nitrogen battling it out with the heat from a class A Pass amp. The front lines of the battlezone would have its own weather system: miniature hurricanes, hail, etc...
speaker oil for better sound
Having rescued three scratchy old speakers now by liberally spraying them with WD40 I think I know why it works.
Basically, when you soak your speaker cone with WD40 it makes it more slippy so the sound particles can fly off it better. Don't know why I didn't think of this before!
mmmm.... at least we'll get Cool sound from that....Probably right enough, madness is unrestricted by time or budget.
Next 'upgrade' we cryo treat the national grid
Kinoshita Monitor Rey AudioThese are the "refrigerators" I want to build for myself someday.
Well, WD40 is a mixture of several oils I've read. Maybe one of them is Snake. Wonder how many snakes needed to get a an ounce of oil?
They get iy from the cosmetic company that you showed.Well, WD40 is a mixture of several oils I've read. Maybe one of them is Snake. Wonder how many snakes needed to get a an ounce of oil?
Virgin Cold Pressed Snake Oil is the best. $$$$$ tho.
Right. Like you'd be able to tell it from slutty, hot pressed snake oil without peeking.
se
- Member Areas
- The Lounge
- Funniest snake oil theories
