Moving forward, the kits will likely move to the ES caps, as my supply for KZ has also dried up.
Some in the GB will receive ES caps because GB exceeded supply of KZ caps.
No worries because ES (UES Bipolar) are super good, tested correct for stability in the UltraBiB prototypes as well. And you can't orient them the wrong way even late at night
P.S. They behave well with DC bias also
ok i cant wait to get the kits, i would like to order the transformers now. what trans should i buy to get +-12 from the BiB and to get 5 volt from the Reflektor to power a Soekris DAC?
The UBiB build guide says "15VAC for 11-15Vout". For the 5Vout Reflektor use 9 VAC
Both 30VA or 50VA
P.S. If its a special order single transformer you can ask for 50VA with 15+15V 1A each side independent secondaries (four wires) plus a 9V 2A secondary
Boards were delivered today. Many thanks.
Parts arrvied from mouser last week. Time to heat up the soldering iron...
Good luck and let us know how it went in the UBiB's main thread
Both 30VA or 50VA
thanks. i just saw that guide for the first time. Got one 100VA 15VAC andd one 50VA 9VAC from antek. would that be fine?
King size but alright if you think big. Has to be 15+15 (two independent secondaries) the 100VA guy because you look to make a symmetric Ultra
AS-1215 - 100VA 15V Transformer - AnTek Products Corp
Unfortunately I missed this GB.
Are there any boards left? I would like to have one board and three mini kits (2 pos, 1 neg) if there is any possibility.
thanks
Klaus
Yes. I still have some stock. Let me know if you need any of them to be 5V supplies, and I can pack parts accordingly. Private Message me your email and I will invoice you. Best Regards,
Tea
Received both kits today. thanks. im not sure if the kits are complete or do i still need to order some parts?
You need to order parts. These are minikits. The first Post has a link to a spreadsheet that has the minikits, and extra parts to order for a complete board population.
Here is the link to just the BOM part of the first post.
UltraBIB Minikits - Google Sheets
Note the R1 requirements in the build manual.
- Group Buys
- GB For Salas SSLV1.3 Ultra-BIB
