Well if the new GB comes I am in for 1 x board and 2 x IRF+.
In the meanwhile I am looking at the spreadsheet but this raises some questions.
My question is what I fill in for the constant current an load consumption. I want to drive +12V with 500mA. I have a 50VA 2 x18V (1.36A) toroid lying around.
I want to power with 5V 250mA for an Odac. Do you sell complete kit?
Στάλθηκε από το GT-I9300 μου χρησιμοποιώντας Tapatalk
Panos444, be paitent , more news coming on that in a few weeks.
But we can likely do a full kit or pretty darn close.
Is there any group buy for PCB going on? I am looking for a IRF + and - BOARD/kITS?
Sign me up for 1 board and 1 mini kit. Thanks. -marsupialx (Jeffrey Hill)
You guys are added.
Panos444 is removed.
I will try to get sign up sheet online asap.
NEW GB
Greetings, a new GB sign up is open for these boards.
First post explains the boards, and terms.
http://www.diyaudio.com/forums/grou...-salas-sslv1-1-bib-shunt-reg.html#post2571174
The Low Voltage shunt kits will now be offered as a Reflektor-D board kit, as the majority of users were using it for digital. This is a new product. Check GB post here.
http://www.diyaudio.com/forums/grou...ektor-d-digital-power-supply.html#post3974245
The current GB will be open until 7.20. Please sign up in the google spreadsheet link in my signature.
The kit prices have increased. The cost of the 2SK117GRs has tripled for me.
Private message me your Paypal email and I can send you an invoice after you have signed up on the spreadsheet.
What do I need to build a +12 V 1.5A PSU and a + 5V 1A PSU. New to this but have built a number of other things just never a seperate powersupply from scratch. The 12 volt is for a DDdac 1794 stack and the 5 volt is for a Wave I/O USB board. Output will be couple with Cinemag 15/15B2 line in transformers.
Suggestions and advice would be greatly appreciated.
Thanks,
jgwtriode
Thanks,
jgwtriode
IRF9530 in both positions, strong sinks, 5W properly calculated Rset. You always set for at least +10% than max load draw. Read guide and use XL calc from post#1.
Where do I find post #1?
As far as what I need to buy from the spread sheet? Are the sinks available there adequate or should I get larger ones. Do I configure both supplies with
9530's. Are the caps include in the full kit? Or is the nichicon cap a bundle of
the necessary caps? Do I also need an IRF+ kit? You also talk about hot rodding being subjectively better. Is that approach applicable to what I am trying to create here?
- Group Buys
- GB Thread for Salas SSLV1.1 BiB shunt reg
