I also signed up in your exel form i need a BiB board with (full kit) all the materials you can provide to improve the power supply on my soekris r2r dac. Please inform me when you are ready to send and please check if the kits i signed up for are ok for a BiB like this
http://i1.wp.com/www.dimdim.gr/wp-content/uploads/2015/02/IMG_9144_resize.jpg
I'll wait until you have full kits available.
FYI:
I only sell Minikits for the BIB, there are otherwise too many variations to account for.
The BIB kits are spelled out below.
MiniKit BOM section. This links goes to full details of all the parts included in the kits and there respective positions on the board.
http://www.diyaudio.com/forums/blogs/tea-bag/741-salas-board-minikits-full-kits.html
The BJT+ kits can be made, but typically the Reflektor-D has been the effective replacement in this range.
I will look at demand of boards and discuss with Salas. I know he is trying to get a revision (only artwork) to one of the boards. So I am not sure if that is in limbo.
Regards,
Tea
GB for Salas Boards happening now! Ends April 19th 2015
Group Buy period is in effect, and will end at 4/19/2015
Okay, if you have signed up for the GB, you should have received an PM with instructions to deal with payment.
If you have not signed up for it, either enter your DIYAUDIO name into the spreadsheet linked below, or Private Message me and we can take of it from there.
PM sent!!
Signed up in spreadsheet!
PM sent!!
When will you send out Paypal invoices?
I sent you a PM back about shipping? Did you see that? I need an answer to that, as I usually do not do trackable shipping unless it's EMS shipping which is very expensive. However, there are a number of people who use it because of local shipping issues.
Regards,
Tea
B]The GB for the Salas board is open for payment up until 11:59PM EST 4/19/2015.[/B]
Payment is via PayPal invoice only. You will need to send me your paypal email via private message for me to start this process. Then I will invoice the parts you requested from the spreadsheet.
BIB
The BIB is a low voltage regulator. It includes 2 positive and 1 negative regulator per board. These have been upgraded to 2mm thickness from 1.6mm. Board production costs have risen , cost is 25.00 per board.
The builders guide is available here in the first post, as well as a current and voltage setting calculator to get the other parts.
http://www.diyaudio.com/forums/grou...-salas-sslv1-1-bib-shunt-reg.html#post2571174
The minikits for the BiB are available for 12.50 each. They do not include all parts to complete a section of the board.
More details on the Minikits are in the Minikit link below at the bottom of this message.
Here is a picture of the board. Each one includes two positive and one negative rail board. They are scored and can be broken apart
Here is a picture of a mini kit
BIB
![](https://origin.dastatic.com/forums/gallery/data/1729/BIB-SMALL.jpg)
![](https://origin.dastatic.com/forums/gallery/data/1729/BIBMinikit-small.jpg)
IS there a bom for the regulator ?
I recommend reading the build guide in first post. After that, the calculator, also referenced there can be used to get the parts one needs for their specific voltages. I find the calculator pretty reliable.
I would like to order the following Kits:
1 x Salas BiB +12V MOSFET
1 x Salas BiB -12V MOSFET
It´s for my Soekris-DAC!
Christian
Christian,
I will send you a private message detailing what I have.
Regards,
Tea
- Group Buys
- GB Thread for Salas SSLV1.1 BiB shunt reg
