Charles Hansen said:Inadequate output stage current gain is a real problem. It's definitely one of the blind spots of Self, and also one of the virtues of the Leach design. (Leach's output stage was taken directly from Bart Locanthi's "T-Circuit" of 1966.)
True..
![nod :nod: :nod:](https://files.diyaudio.com/forums/images/smilies/nod.gif)
Charles Hansen said:True story -- There's a guy named Andrew Hefley that is a very good solid state designer. Do a web search and you'll see he has a long and distinguished resume. You can even see some of his circuits in an app note he wrote for Motorola (now available at On Semiconductor).
About six or eight years ago, he heard his first single-ended triode. And do you know what he did? He quit the business. Now he makes instrumentation for light aircraft.
He told me that after 30 years of designing solid state audio amps that he figured he knew it pretty well. But after hearing the SET, it showed him that pretty much everything he knew and believed was wrong. Instead of going back to the drawing board, he literally quit the field.
On the basis of his motorola design, i am not surprised!
Hi, Mikeks,
I really, really wanted to see audio amp of your design. Can I see an example of 1 of your design (don't need to be the commercial one)
Eccentric?Originally posted by Ouroboros He was a lecturer of mine at university, and even back 30 years ago he was more than slightly eccentric.
Re: Phase distortion
Is there a similar effect in FET current sources?Variable capacitance in the current source collector junction especially would cause phase distortion.
dimitry's paper in the September 1996 JAES would appear to disagree: http://www.aes.org/journal/toc/sept96.htmlOriginally posted by mikekssingle-pole Miller compensated amplifiers..
this inferior frequency compensation technique
Miller compensation remains unmatched when compared to feedforward and pole-zero compensation
It also seems to put Hawksford's EC into a category of no better than NFB:
The authors compare two generalized amplifier correction topologies and find that both exhibit the same sensitivities to changes in the main path as does negative feedback
At least, that's what I take the summary to imply, as I'm too cheap to pay the $5 for the article. I've never come across a journal that charges even members for access to an article -.- ... if I had realized they do that, I'd have never subscribed to the AES.
Ordinary Miller compensation is sub-optimal
While ordinary Miller compensation is quite good for stability, I have found it to be less than the best for matters of high-frequency distortion. In fact, many amplifiers that suffer from soft or hard slewing distortion (or TIM) do so because of the way the simple Miller compensation works.
For those interested, my 1984 JAES paper on a MOSFET power amplifier with error correction (based on the Hawksford idea) is now posted on my fairly-new web site at www.cordellaudio.com.
That amplifier does not use simple Miller compensation. Instead, its main compensation is provided by what is effectively Miller compensation by feedback from the VAS output node back to the inverting input node of the input differential pair. The loop so formed does itself also need compensation, albeit at a much higher unity gain frequency, and that is provided by a simple series R-C shunt across the collectors of the cascoded input differential pair. This kind of compensation results in extraordinarily high slew rate capability and HF linearity without the usual compromises of classic simple Miller compensation.
I have also posted some other papers at www.cordellaudio.com that may be of interest on some of the subjects covered in this thread. Unfortuantely, a couple of those papers were scanned in with poor quality, for which I apologize. I'll try to fix that this weekend.
One of those papers is the one on Phase Intermodulation Distortion (PIM), what some have referred to as "fm distortion". That paper describes the origins of PIM, what it has to do with negative feedback, instrumentation for measuring it, and actual measurements on amplifiers with and without negative feedback.
Note that although it employs substantial amounts of negative feedback, the MOSFET power amplifier with error correction was measured to have less than 100 picoseconds of PIM.
Bob Cordell
Bob Cordell
Miller compensation and Open Loop Bandwidth
While I am not a big fan of Miller compensation, there is no reason why Miller compensation cannot be used while achieving high open-loop bandwidth.
Indeed, high open loop bandwidth is usually achieved by getting rid of the extra loop gain that would normally be there at frequencies below 20 kHz. Such a reduction in low-frequency open loop gain is usually accomplished with either a resistive load on the VAS output, or a local feedback loop, or some combination of the two.
Bob Cordell
Bob Cordell
It is no relation between OL bandwidth and Miller compensation. Lowering gain at certain frequency by cap/resistance to ground is just wasting the available OLG. Miller compensation exchanges reduction of OLG for low distortion inside Miller loop. Miller compensation allows to make the second pole time constant (associated with VAS load) smaller.
Re: Ordinary Miller compensation is sub-optimal
I think you'll find that, strictly speaking, your amp. uses series compensation of the lead variety.
The only difference between your approach and the usual phase lead approach (RC network directly shunting feedback resistor) resides in the fact that with the former the RC net (R13/C4) is connected to the second stage's output; output stage singularities are thus bypassed, and a trivial increase in gain margin accrues.
It is because of the later problem, i would suggest, that additional shunt compensation is required with respect to the input stage to augment major-loop stability margins.
I agree: single-pole Miller (or feedback) compensation is not ideal.
However, you could use double-pole Miller compensation to obtain stable loop gains at HF of the same order, at least, as those obtained with series compensation, with the additional advantage that the second stage is made more linear by the minor feedback loop at HF.
Bob Cordell said:For those interested, my 1984 JAES paper on a MOSFET power amplifier with error correction (based on the Hawksford idea) is now posted on my fairly-new web site at www.cordellaudio.com.
Bob Cordell
PMA said:I prefer flat (at least up to 20kHz) and quite high OLG. This results in high and constant loop gain in audio band. For this reason, Miller compensation is not usable, and gives not good sonic results.
Re: Miller compensation and Open Loop Bandwidth
This, alas, is the electronic equivalent of robbing Peter to pay Paul.
The increase in forward-path bandwidth is at the very substantial expense of forward-path gain and second-stage linearity, with no compensating benefits.
Bob Cordell said:Indeed, high open loop bandwidth is usually achieved by getting rid of the extra loop gain that would normally be there at frequencies below 20 kHz. Such a reduction in low-frequency open loop gain is usually accomplished with either a resistive load on the VAS output, or a local feedback loop, or some combination of the two.
Bob Cordell
Yes, of course you are correct. I am certainly not an advocate of throwing away open loop gain to raise open loop bandwidth. I was just pointing out that that misguided approach to design is not inconsistent with Miller compensation. I don't think I have ever seen a case where doing that reduced ANY kind of measurable distortion, including TIM or "f.m." distortions.
Bob
Bob
Upupa Epops said:Gentlemen, is here anybody who have some experiences with Hawksford's circuit ( except Nelson, Charles and me ) ? Theory is theory, but tree of life is green.
I have. I have a power stage that uses Hawksford EC, driven by a front end voltage amp with H.EC. Works like a charm, no stability problems, no compensation, reasonably THD free. OL gain and CL gain are identical, only better linearity with H.EC.
Jan Didden
janneman said:
.......... driven by a front end voltage amp with H.EC.........
Jan Didden
Elucidate..
In one of his papers, Hawksford generalizes his EC method to stages with arbitrary gain -- it's not just for followers with gain close to one. This is old news.Originally posted by mikeks
Elucidate..
mikeks said:I am cognisant of that, but would rather see Jan's practical implementation, if that's fine with you old chap.
You have mail...
- Hawksford
