Hifonics Brutus BRZ1200.1D
One more try with my digital scope.
When I use both channels of the scope in differential mode, channel 1 on the gate and channel 2 on the source, the display is a straight line. The two probe signals seem to cancel each other out. I didn't think that I needed to invert channel 2 since I was using the (-) math function?
The photo is using the Micsig differential probe with the positive probe on the gate. The negative probe is unattached.
I am a little confused in that the Micsig has an X50 and an X500 setting, but my scope only has X1, X10, X100 and X1000.
I am using the X1 scope setting in this photo.
I will connect the load when I get this right.
