Luca, have you measured fr response? Just curious.
I don’t have tools to make measurements on the speakers, so honestly I can’t tell.
During the driver trials, I connected the 3 pairs to a frequency generator: as far as I remember, the 2 weak pairs stopped playing at 50 Hz, while the Visatons went lower.
The highest frequency that my ears could hear was, for all the drivers, around 15 KHz.
If I spare time, I can repeat this rough test with the new cloth for the Visaton. I'll let You know.
Ciao.
L.
I have also over the years have searched for unlikely ready made enclosures and then reverse engineer to choose the the driver. I like your solution here. I would be concerned that the Lack shelf material is vey light ( not dense) and would vibrate and resonate uncontrollably. How do you deal with this?
It could happen, as the wide walls of the shelf are only 3 mm thick ( the others are 7 - 8 mm ).
But they are glued to the polystyrene and wood inserts, that dampen all vibrations.
Anyway, if You want to be sure, You could put some dampening sheets or paint inside the shelf, or little wood blocks between the wide walls.
Ciao.
Luca
Ciao.
Luca
Or maybe the side panel resonance could enhance LF response, like the Reso cabinet for the famous Saba Greencone loudspeakers
Frequency response ( roughly speaking … )
With my “professional” tools: a DIY frequency generator, a TA2024 Amp and my ears, at an ordinary volume level, the results were as follows:
- connected to Lack loudspeaker with Visaton driver:
Fmax: 12.5 KHz
fmin: 42 Hz at the same level of the higher frequencies, then the volume lowered but I could still hear something till 15 Hz
- connected to a cheap 1” full range driver:
Fmax: 12.5 KHz
fmin: 150 Hz at the same level of the higher frequencies, then the volume lowered but I could still hear something till 55 Hz
Ciao.
Luca
Ciao.
L.
Fmax: 12.5 KHz
Fmax: 12.5 KHz
Ciao.
Luca
- Full Range
- IKEA Lack Full Range Speakers
