Thanks. Autotech. Azura. ATH4 designs.... some wood exotica...Autotech claims that the largest SEOS horn could be used down to 300 Hz
Charles
I'm still confused by the SEOS talk. Some say the SEOS shape doesn't work well below 1Khz. Sorry. I don't recall the reference. Could have been just internet nonsense.
The PM60, designed for live sound is a remarkably clean MTM, imo. Uses two 12" horn loaded mid-lows down to 100Hz, and CD on XT1464 horn, crossed around 650Hz. It's what got me started with all the DIY stuff ! https://soundforums.net/community/threads/60-degree-diy-mid-hi-aka-pm60.12390/Exactly.
After tasting some MTM honey, even with a horn-loaded dome tweeter, it's hard to go back to regular TM or TMM systems.
Some (potential) lobing and cancellation issues are dwarfed by the advantages of the vertical embedding of the mid/high section by woofers and the coupling with the room (at 70% of the floor-ceiling height).
That PM60, Paul W's Raptor, and some of your and other's words helped me decide to use the XT1464 horn.The PM60, designed for live sound is a remarkably clean MTM, imo. Uses two 12" horn loaded mid-lows down to 100Hz, and CD on XT1464 horn, crossed around 650Hz. It's what got me started with all the DIY stuff ! https://soundforums.net/community/threads/60-degree-diy-mid-hi-aka-pm60.12390/
http://www.htguide.com/forum/showthread.php?35812-The-Raptor-a-10-quot-MTM&p=492591#post492591
Paul W also uses the Radian 951Be is his Octagon 2.0 design:
http://www.paulwav.com/octagon-2-0.html
I'd love to hear more from him on his use of the Radian 951 with it's negative 7deg exit angle. I'm using the PB version with the XT1464 horns. Project still in progress...
It must be < 1/4 WL for ~complete summation with a max of 1 WL as an acceptable compromise for most apps, though note that as we move further away the gap can spread proportionately and why widely spaced PA stacks can sound as one large one: https://www.birotechnology.com/articles/VSTWLA.html
CTC distance could be improved, indeed.CTC distance looks also really high on the Wilsons.
Charles
The more I learn about acoustics and loudspeaker technology, the more obvious it becomes that a loudspeaker system is actually a composition of numerous trade-offs.
On forums that are mainly focused on technology and science, a typical (programmed) human characteristic becomes evident: being blinded by, or, having blind faith in science.
An example to avoid an endless disquisition: There are countless loudspeaker systems that meet certain technical/scientific ideals: optimal (polar) response, low distortion figures, etc., that nevertheless cause headaches, and or fail to enchant you by the music.
Often these characteristics may even be desirable, eg studio monitoring. In this case, loudspeakers are tools; instruments for the production of music.
As for Wilson Audio, the only achievement that inspires me in the long history of the brand, are the 4 brAun Output C mini-monitors in the original WAMM, as well as the concept of the original Wilson Tiny Tot (Watt) with the SEAS CA 17 RCY midwoofer that was developed by Jan Paus.
Compare the cones, dustcaps and surrounds with those of the ScanSpeak woofers in later Wilson products.
This seems a stretch, and very contrary to what Toole has found.
Toole and I agree on at least 2 very important aspects that are often ignored and dismissed:
1. There are limits to (his) knowledge
2. Personal preferences ultimately play a decisive role, not least because personal circumstances (room conditions, etc.) can strongly deviate from 'scientific conditions'.
I think it's important to remember that Toole was searching for the mean of consumer preference.
I'm not sure the mean of consumer preference translates to accurate/linear acoustic amplification.
I view his work as more of a statistical marketing study, rather than a scientific study of accurate loudspeakers.
But folks want to see his work as saying "this is what makes for an accurate loudspeaker."
I don't buy it......
Anyway, just my 2c
Anyway, just my 2c
To avoid misunderstandings, I have nothing against science, as I have an academic background myself.
My starting point is: What is (the relevant) science with regard to a certain topic?
For instance, many people believe that virology is a science. In that case, a universe of wisdom can be gathered, whereby the level of abstraction determines the value of the insights to be obtained.
I don't have any kind words for this, possibly the most inaccurate way of looking at the man's work.I view his work as more of a statistical marketing study, rather than a scientific study of accurate loudspeakers.
The most impressive demonstration I heard was a 1"/15" aktive speaker from ex meyer sound founder in switzerland who runs his own manufacturing company. The 1" driver outperforms 2" drivers, but is faster. AP uses Ferrofluid in all their drivers. You can cross low and you can go loud and fast! Impressive!
Thanks for the straight up comment.
I did not mean to demean Mr Toole. I think he is honest, and forthcoming with all he writes.
I think folks don't pay attention to his full disclosures, and often become "the errant disciple".
just a bug up my ***...my apologies. And thx again![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You're welcomeThanks for the straight up comment.
A much more accurate statement.I think folks don't pay attention to his full disclosures, and often become "the errant disciple".
"The horn does play a big role. With that said. Even on the giant 2360A the Axi2050 still runs out of gas due to diaphragm displacement limitations near 300Hz. This isn't really seen until absurd output levels with more than 10 volts applied = REAL LOUD, so technically you could get away with a 300Hz Xo on that horn in most cases."
https://data-bass.ipbhost.com/topic...pression-driver/?do=findComment&comment=24944
I did build an MTM a few decades ago. Floor standing. Resistive vent. Used Dynaudio drivers. 17W75 woofers; and a D28 tweeter - the dome with the horn. They were very good. No low bass, but lot's of slam.
It is probably no coincidence that I also have quite a bit of experience with Dynaudio. During my hi-fi years I've owned several Dynaudio loudspeakers of the Contour series and Crafft monitors. In addition, I have bought Dynaudios on behalf of customers and friends.
In the 80s and 90s Dynaudio became known for the quality of the drivers. The vintage drivers are still sought after by hobbyists today. Judging by the (attached) spec sheets of the drivers that you've used, it becomes clear why.
However, my eyes (or rather: ears) were opened when I experienced 'high sensitivity' loudspeaker systems at the beginning of this millennium. From that moment on, my view on loudspeaker technology changed.
Ditto.I don't have any kind words for this, possibly the most inaccurate way of looking at the man's work.
But I guess that's been settled now.
- Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
