Although I also use spice simulation, I dont go too much into the accuracy of the spectrum. In most instances the most I can say is that it gives a good idea of which harmonics will be the promiment ones and sometimes spice even gets this wrong. Compare for instance the sym amp spice file with the measurements obtained by pavel who measured this amp. The prominents are correct but as for the rest of the accuracy well......
Sorry I should have mentioned that its a good idea to place a 5 to 10pf cap between the gate and source if you run into stability problems.
Im not sure what your schematic looks like at the moment but I would surely drop the current through the jfet usualy to around 3 - 3.5 ma when used in a cfp. I wasnt aware that spice would show the effect you discribed but in real life at a certain current the jfet will tend to drop thd by quite a margin and in singleton mode mostly its odds. On 6 - 8 ma IDSS parts I usually get it at around 2.5 - 3.5 ma when used in cfp. I think John Curl once gave a explanation for this.
I think this design is so simple one can easily try many variations till you find one that best suits your musical tastes. My preferred one was the folded cascode and beta enhancer as Self calls it, good for accurate reproduction which better suits rock, electronic music or a amp for AV purposes.
I didn't have stability "problems" as such - it's more that most of the mods I have been doing recently have been aimed at reducing the compensation to an absolute minimum without sacrificing a smooth sound i.e. increasing the "speed" of the amp - the CFP took it in the other direction. The CCS on the i/p stage gives lower distortion than the CFP and has much less impact on Stability - but I will try the small cap as you suggest.
Could show direct me to an example of the folded cascode & beta enhancer - I have built a folded cascode amp but not sure if your suggestion is similar.
cheers
mike
cheers
mike
referring to the cct here:
http://www.diyaudio.com/forums/soli...s-lateral-output-perfect-209.html#post2743197
This graph shows the effects of different size filter caps on PSRR as compared with a separate supply.
I was injecting 1VAC into each rail at with a 180 phase shift between rails - this was the most challenging noise source.
My supply is already very low noise but it will be modulated by the signal so I think any mod that brings improvement here will be significant.
In reasonable simulations, I don't think I've seen anything over 70db. Since even Cordell's models suggest ~70db possible rejection, I'm willing to believe it can be done. But for some reason the ones I built, along with those of a friend, were between 50-60db. I suspect it is the protection diodes I use, and perhaps the diode models in SPICE are off. OR, maybe my measurements were contaminated.
EDIT: I don't know, I seem to be close to SPICE predictions, the version I use on my Fetzilla gets 67db isolation for the 120Hz ripple, at 230mV in to 100uV out. I just measured this. So I'd say it can vary between 50db-70db, and quite possibly below 60db means something is wrong.
I don't think 100db could be achieved in practice without adding extra filtering in series, because the filtering of the multiplier at all frequencies is limited by the Early effect of the transistors, irrespective of the RC network.
I have posted more advanced schematics involving an extra filter in series, but they are not so economically impressive as the K-multiplers themselves...
- keantoken
- keantoken
I understand that is a significant limit at the input LTP and if you have the chance to read "Self on Audio" there is a good article from EW, May 2003 there, with sims and experiments, entitled "Power Amplifier input currents and their troubles". One solution to early effect ripple induction was the cascoding of the tail with just one cheap transistor. Watch where you bias it though - the midpoint of the CCS reference earth resistor was used in the model, where a decoupling cap to the rail is also commonly fitted.I don't think 100db could be achieved in practice without adding extra filtering in series, because the filtering of the multiplier at all frequencies is limited by the Early effect of the transistors, irrespective of the RC network.
That's true. Since the input transistor is where most of the bad PSRR comes from in this amp, a cascode there may be as effective as frontend supply filtering. However then the VAS is not covered. But, we know that others have found worse SQ when moving the VAS to a different rail, so this may be the best option for both worlds.
There are many ways to fix the Early issue for the K-multipliers. However from a simplicity standpoint, I think this is the point of diminishing returns. If you need more than 60db of supply isolation that goes deep into bass, then you probably will want to customize the design to your application, and a one-size-fits-all is no longer reasonable.
- keantoken
- keantoken
For me I will build a separate regulated supply for the i/p & VAS stages. I think this is the best solution and perhaps later will see if I can come close matching it with other methods.
But also the secondary advantage that I can now have a few extra volts on this supply which will me especially useful if I end up using the driver devices before my o/p mosfets as these will use an extra volt or two.
I just added 22,000uF across the 470uF filter cap.
I recommend this mod ( or something else that addresses this PSRR issue ).
Subjectively it helps the solidity of the bass, smoothness in the midrange and general feeling of effortlessness.
It makes it sound like a much more expensive amp
mike
mike
I thought Kean was saying that 50 to 60dB PSRR was about as good as it gets.
If instead he was saying that is a limitation that only applies for his (or similar) Multiplier then your results are showing that a simple RC filter can give better results.
If that is the case then the limited PSRR multiplier is performing less well, than an RC filter.
The best solution for this is to take a voltage doubling tap from the PSU's to get about + & - 50V and then use a good CCS / shunt regulated supply for the ip & VAS to take it back down to about + & - 30V for full DC regulation.
As my 4 x 22,000uF caps cost about 40 pounds in all the above solution may also be cheaper - but not simpler, adding the caps is about as simple as a mod can be.
I will probably design a new board for an i/p buffer and + & - regulators but for now I'm just enjoying the big caps
mike
mike
- JFET input, MOSFET VAS, LATERAL output = Perfect!!
