The problem is that the S-D dac chips are sensitive to audible jitter effects like I described that have not looked for or reported in the literature, at least that I am aware of.
Markw4, there's an old article in Stereophile by Rémy Fourré (of UltraAnalog at that time) that talks about this problem:
Jitter & the Digital Interface Page 2 | Stereophile.com
As to the 'external' digital filters you've mentioned a few pages back, I fully agree with you, but (!) the biggest problem for many is that working with DSPs or gate arrays calls for completely different set of skills (and tools), which not all of us have.
One of my sources has a PhD in electronic engineering, 45 years experience at least, and designed D-A converters professionally when I first met him in 1972. Later, he made some very good digital audio delay lines, before he diverted to electric cars, where he got at least one important patent. How could he know anything?
It is entirely possible to be smart, successful, and yet arrive at the wrong conclusion. Witness most of this thread.
This argument about Delta Sigma DACs is old and tired at this point. Let's use a metric you like to use - if they are so bad, then why does virtually every single top audiophile rated box use DS converters? Even your old buddy Charles Hansen was using them in their flagship products, for quite a long time, too. I think he was even using PCM1738 in products earlier than many adopters.
It is interesting that none of the players in the industry decided to come out and say their new DACs sounded worse than the old ones when they replaced their PCM1702, AD1862, AD1865, TDA1541, etc. based designs. The Stereophile reviews certainly didn't get less effusive.
There you go, "proof", JC style.
There is not a shred of legitimate evidence that DS converters inherently sound worse, you will have trouble even cherry picking / crowdsourcing impressions with the success and wide acceptance of DACs like the newer AKM and ESS parts.
Since you seem to value subjective impressions - for what it's worth (not much), I have listened to multibit DACs built with AD1865, PCM1704, and TDA1541A and I found there to be no obvious differences that would be attributable to their converter architecture.
You should consider that maybe your friend's ears aren't the best point of reference and that his observations are biased due to his feelings and experiences with said topologies.
I've got >1 patent and the PhD-EE. If someone can bring the experience side, I think we can make this happen quickly.
*My Ph.D doesn't deal a lick with circuits or analog/mixed-mode, which should further give credence to my opinion that DS DACs are great. (if anyone is taking me seriously...)
I’ve got 7 patents in Canada, US, Europe and the Far East, the PhD-EE and 35 years of experience.
DS-DACs are great, there
My colleague probably has several patents, in fact he is doing a patent application right now for his digital solution that EXCLUDES delta-sigma converters. I just know about his one electric motor patent, because he had some professor reveal it when it was supposed to remain confidential. You guys don't hold a candle to him, in his areas of specialty.
Approved patents are public by nature (what's the point otherwise!), albeit government agencies do classify some from time to time. So that doesn't make any sense.
Most of us can't hold a candle in other's respective areas of specialty, whoop de doo. The world is pretty complex and breadth and depth are no longer a reality in the same way as when our understanding of the universe was smaller. I work in a massively multidisciplinary operation -- it's a miracle some days I retain as much as I do from talking to several of my colleagues because their domains of expertise are so far apart from my own (and I'm more of a glue person than most in our institution!).
Electric motors are a bit afield of new DAC topologies, though, no? And since you're not an expert in his area of specialty, how are you a good judge of his talent? What if he's pulling your leg?
T, I often listen to digital radio during the day, usually Blues. Sounds OK to me. I then use the same Sequerra Met7 speakers that Scott uses. No highs or deep lows, but it sounds OK with rock and roll, or the Blues. I am often surprised that it sounds that good. I only turn on my $50,000 system for serious listening.
When the day is done, at least I can measure an inductor, unlike syn08. Ha!! And my equipment at home doesn't say "error 25". That is, if I actually had any.
I actually can measure complex/vector impedances, with the other half of my lab setup, not in the photo. Up to 40GHz, that is, and with no error 25
I probably should have worded my initial reply better. He might even be a master DAC designer, but his conclusion that they all "sound bad" is unsubstantiated at best.
I'd rather evaluate the claim and not just the CV of the person making it. History is littered with brilliant people that were wrong sometimes.
Maybe I am wrong here, but I've seen no credible theory or data, and this is one of those topics that's come up routinely over the past 20 years on this and other audio forums.
I am suspicious of delta sigma converters is because I do listen to them. They just sound slightly 'wrong'. It would appear that Markw4 might have an explanation. Thank you Mark for your input. I take it seriously.
Well, you self admittedly don't know anything about digital. I am not sure why you would immediately blame it on the converter topology. Mark's explanation will not hold up to any sort of rigorous analysis.
Forgive me if, again, I do not trust in sighted listening tests performed by representatives of the most hearing challenged group in the population.
My PhD friend rejected delta sigma converters on purely mathematical grounds.
He didn't have to listen to them. He found better potential solutions.
http://www.essentialaudio.com/1-Bit-Is-Bad.pdf
Markw4, there's an old article in Stereophile by Rémy Fourré (of UltraAnalog at that time) that talks about this problem.
Thank you for the link. However, I think we can show there are more timing compilcations than just jitter. I am talking about absolute signal edge arrival time vs dac master clock phase affecting sound quality and this is for signal inputs intended to work with asynchronous incoming data. I wasn't expecting as much sensitivity there. Could be if there is enough jitter it would swamp the above described effect, but its there, and plainly evident when jitter is low enough.
This is more about DSD.
Every single in-production audio converter IC that I am aware of is a multi-bit Sigma Delta, though.
JC, Wanted to follow up to say when I mentioned clocking, I wasn't talking about oscillators per se. More along the lines of generating multiple very low jitter clocks at different frequencies and perhaps with different relative phasing, all from one ultra-low jitter master clock.
Can you explain what you mean? This makes no sense to me. You do realize there are registers in the DAC, right?
Each DAC chip maker runs their own noise shaping standard.
Sony, Panasonic, Yamaha, Pioneer etc noise shapings all sounded different back in their day.
One might sound 'right', which one ?.
Dan.
Each DAC maker runs their own noise shaping standard.
Dan.
In which component do you surmise there is noise shaping? Who makes such components for these big 4 electronics companies? Where do you get this stuff from...
Personal remarks about "serious listening".I only turn on my $50,000 system for serious listening.
In fact, and I try to understand-it, with age, I listen less and less to my big system.
When I listen to a live concert on the average speaker system of my computer (full range +sub), I am totally focused on the play of the musicians. Not so much in concern with the "sound".
When i'm on my TV room where is my big system, i'm more in concern with the "technical quality" of the reproduction, so, how to say, less "relax" (easy listening).
Often disturbed with little defects in the mix (my system forgives nothing), and, in the same time, asking-myself if the little imbalances that i notice most of the time (différents in each records) come from flaws of my own speakers, because they are from my design (I had spend months to voice them)... or from the mix itself, or ...
Some (rare) records are perfect, impressives, and it is an incredible pleasure. But, even there, I can not stop looking for something to improve.
So "serious listening", as you call, is quite tiring for me.
Perhaps it is impossible for a sound engineer or an audio designer to listen to what people call hifi without finding himself somewhere at work ?
Maybe I should ask a psychiatrist to come to my rescue ?
All those thoughts not to tell my life, but to ask a strange question: What is the limit of presidency, transparency and dynamic of a home "hifi" system beyond which it is *too much*.
My mother, an artist, used to say:
"The closer you get to perfection, the more distant it seems."
Nothing to do with the registers. It seems more like something having to do with setup time and or DPLL comparitor triggering accuracy vs time. Something like that. This is for an asynchronous input signal such as a DSD clock that has to be tracked by the internal ASRC DPLL.
Still makes no sense to me, oh well.
Hilarious in a way actually, a flood of buzz.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
