prasimix & Co.:
I've been distracted the past few months and am only now about to start working on this project. Prasimix's latest posts have me worried -- I bought a pair of FL18/18 transformers from Allied Electronics (Block - FL 18/18 - Uncategorized - Allied Electronics) and am wondering if I should have gotten the 15VAC version instead.
I can check to see how these transformers are performing before soldering them onto the power supply pcb, but can anyone clue me in on what the unloaded output of these things ought to be? It'll presumably be something North of 18V, but what should the maximum acceptable output on the secondaries be for this project?
Thanks for helping this dope out.
Regards,
Scott
If you add resistors as suggested by AndrewT and shown in post #217 you should not worry.
Folks:
Another question: the jumper between R16 and R24 on the single channel preamp board is a series of dashes, not a single line. Are there circumstances when that jumper is not needed? Do the dashes signify something else?
Regards,
Scott
This jumper is optional. Use it ONLY if you'd like to bypass output buffer stage.
Folks:
Can someone explain to me the purpose of the phase splitter? I understand the concept at the 10,000' level ("a single-phase current is split into two or more currents differing in phase") but not how it applies to this circuit. Stated another way, do I want to include the phase splitter in a single-ended application?
Thank you,
Scott
Thank you,
Scott
Folks:
Thank you,
Scott
That is just an option added for people who would like to make a splitter mentioned in post #271.
Just stumbled across the link to the GB spreadsheet. Can you please put me down for (1) dual channel board for the 2nd run?
Thanks!
Done.
Hello,
please put me down for 3x stereo pre amp off each single /dual pcb`s.
Thank`s
Gisle
I added 3xdual, please let me know if you also need 3pair of single since I'm not sure what you want.
I'd like to test this preamp and your great boards ... Can you please put me down for 2 single channel boards for the 2nd run?
Nicola/touchdown
Done, please let me know if you need PS PCB.
Hello,
yes i`d also like 3 pair of singles, 6pc, that makes 3 stereo pre amp`s correct?
In total i end up with 6 stereo pre amps, and 9 pcb`s, if i have understood it correctly...
Thank`s
Gisle
Changed to total of 9 PCBs. Also please let me know if you need PS for single channel solution.
Question about Power supply...
Looking back to the first GB, it seems that most of the people choose to combine single ch and one PS (power supply) PCB per channel.
Since I'm preparing second GB, I'm wondering if make any sense to merge single ch PCB with PS? To make PS layout more attractive I'll also add pinout for Hammond transformer. Another possibility is to offer PS with shunt regulation.
I'll also remove "phase splitter" section which seems that made more confusion than flexibility.
Please let me know what are you think about mentioned ideas.
Hi, please count me 4 Dual channel sets.
Thank`s
Done, thanks.
- Group Buys
- Juma's LSK Preamp - through hole version
